help with warning light meanings : V-Twin Forum: Harley Davidson Forums
Old 02-19-2009, 09:15 AM   #1 (permalink)
lsdragons wants to know Dino or Syn?
Background - riding my 2006 Street Bob home yesterday and 2 blocks from home I hear an odd sound - seemed to come from front of engine. Seemed to lose power for a second - then returned to normal. Happened a couple more times - then normal.
Started this morning - and got 1 block from home - everything sounded and felt normal - but noticed
1) the RED Battery Light had come on and stayed on
2) the YELLOW Engine Light came on and stayed on
Returned home - drove truck to work. Don't have owners manual with me.
What do those lights "really mean" and what should my next step be?
Thanks - Lance
lsdragons is offline   Reply With Quote Quick reply to this message
Old 02-19-2009, 06:24 PM   #2 (permalink)
JPHarley's Avatar
JPHarley wants to know Dino or Syn?
Pull the codes from your speedometer. Not sure how it works on your bike..but I hold in the button on the odometer while turning the ignition to on. Then you scroll through the codes. You can probably get a list of the codes off the internet.
2009 Dyna Low Rider
JPHarley is offline   Reply With Quote Quick reply to this message
Old 02-19-2009, 07:47 PM   #3 (permalink)
bill corkey's Avatar
bill corkey wants to know Dino or Syn?
suggest you fix the battery/charger problem first;might be the cause of the engin light also.
Bill
2011 TRI GLIDE merlot sunglo
and for fun a
2006 sportster roadster
bill corkey is offline   Reply With Quote Quick reply to this message
Old 02-20-2009, 05:23 AM   #4 (permalink)
jmpancoast1 wants to know Dino or Syn?
+1 - I would check the cable connections at the battery first, then check the ground connections at the frame behind the battery box. Remove the battey box to get to these easily.
jmpancoast1 is offline   Reply With Quote Quick reply to this message
Old 02-20-2009, 07:25 PM   #5 (permalink)
dynarule's Avatar
dynarule wants to know where he is and how he got here
Thanks - Lance
HMMMMMM strange noise?Maybe the famous two piece rotor? Destroyed stator?
dynarule is offline   Reply With Quote Quick reply to this message
Old 02-21-2009, 10:22 AM   #6 (permalink)
Fat_Bob_08 wants to know Dino or Syn?
Error Codes
The attached .doc is a list of error codes. Hope it helps.
Fat_Bob_08 is offline   Reply With Quote Quick reply to this message
Old 02-21-2009, 10:44 AM   #7 (permalink)
ratt196635's Avatar
ratt196635 wants to know Dino or Syn?
1+ sounds like it cratered on ya!
2008 Street Bob
Wide glide front end
16 inch ultra classic front rim
Thunderheader exhaust
Skull headlight
Skull turn signals
Skull breather
Skull horn cover
ratt196635 is offline   Reply With Quote Quick reply to this message
