Originally Posted by mpjsols
Riding along, loss of drive, pulled over, rear sprocket loose. All 6 bolts vibrated loose, bend in that holds the chain guard on, there looks like a space loose where the sprocket goes on.
Do I need to strip down, or just replace bolts - anyone had this happen - looks like the bolts just vibrated loose. I had the belt changed a couple of hundred miles ago - I guess no loctite ?
Appreciate any help on this one guys.
If you didnt do the belt change yourself, bring it back to whoever did. The way I see it, they owe you for a pulley, belt guard, and possibly a rear wheel/hub.
Plus, thats not cool. They should have used red loctite when they torqued down the bolts (blue at least). This issue shouldnt come out of your pocket.
Man, I would be pissed off!!
Glad you didnt get hurt as a result of someone elses negligence.
Dave
