Originally Posted by mnlowrider105
It kind of sounded to me that it needed to be done at an HD dealer for warranty purposes. What the real story guys?
They might "push" that it has to be done by them, but that's not the case. I would keep receipts of the parts you buy (fluids, gaskets, etc.) to show it was done, but they CANNOT require that you have them do it. And I was a tech for 4 years (until recently).
To be honest, what is gonna get done is:
change fluids and filter
check plugs (can find problems this way, such as leaking valve guides, BIG problem in 2005)
check tires / spokes
check/adjust belt tension
adjust clutch (the first 1000 miles, you get the most cable stretch)
adjust throttle/idle cables (same thing, stretch).
USED to adjust primary chain, but new bikes have auto tensioner (ugh, they make 'em too tight IMHO)
We didn't lube the cables at 1k, because we did it at PDI. 1000 miles is too soon to do that again.
And I never saw ANY techs going over fasteners... with every bolt on a bike, you'd never get work out the door. Sorry, but that doesn't happen, at least not in any shop I was ever in. We might check axles & caliper bolts, but that's about it.
Of course, we had our hands on lots of places, so if you noticed something wasn't right, you fixed it. But just going around checking everything.... that would take an hour easy, just changing the "bit" (socket, torx, allen, etc) on your torque wrench, then resetting your torque wrench to the proper setting. Naw... that ain't happening.
Because what you DON'T wanna do, is just start cranking down on bolt without using a torque wrench. Why? Most bolts use loctite... if you wrench on a bolt, and turn it just a hair... you've just successfully broken that loctite patch. Which is what? Gonna let it turn and back out.
I know I'm gonna catch LOTS of heat from people saying, "What? You don't check the nuts and bolts? It SAYS to!". I'm telling you from personal experience... other than some MMI newbies doing it on PDIs the first few weeks, it doesn't happen, at least in the shops I've been in.
