Need help choosing new pipes : V-Twin Forum: Harley Davidson Forums
Old 12-25-2011, 09:44 PM   #1 (permalink)
Painkiller is on a distinguished road
Smile Need help choosing new pipes
Santa brought me a 2012 CVO Street Glide. I want to change the stock pipes for something that will give me a decent thunder, but that will not muffle the sound coming out of the bike's premium audio system. I'd like to get more power out of them also.
Any suggestions?
Painkiller is offline   Reply With Quote
Old 12-26-2011, 09:04 AM   #2 (permalink)
ultrat's Avatar
ultrat is on a distinguished road
I sure like my rush slipons 2" baffles rt side ..2 in on lt side w/ a reducing washer 3/4 in hole in it,, not expensive ither...
ultrat is offline   Reply With Quote
Old 12-26-2011, 10:37 AM   #3 (permalink)
ltrhdevo's Avatar
ltrhdevo is on a distinguished road
for more power 2 into 1
Knuckle Buster
ltrhdevo is offline   Reply With Quote
Old 12-26-2011, 10:46 AM   #4 (permalink)
AKA ARanere
Bronxhog's Avatar
Bronxhog is on a distinguished road
d+d fatcat 2-1 with quiet baffle or the rush slip ons mentioned above if you just want slip ons and not an entire exhaust .
but you may want to remove CAT.,so entire exhaust may be way to go.
Bronxhog is offline   Reply With Quote
Old 12-26-2011, 07:31 PM   #5 (permalink)
FLSTFI Dave is on a distinguished road
First you need to get rid of the Catalletic converter in the stock head pipe.
Several options for that, a Fullsac X- pipe "B" which is for the 110 motors. You use your stock heat shields with this. It works well. I did this on my 09.
My 12 CVO I am using the Jackpot head pipe, which again uses the stock heat shields. It is ceramic coated and has dual 02 bungs for easier tuning.
Another option is the Vance and Hines Head pipe with the power chamber cross over.
Again lots of options on the mufflers. The least expensive is to use Fullsac baffles in the stock mufflers. They come in three sizes, 1.75, 2 and 2.25 inch baffles. As sizes goes up so does the volume. I ran the 2.25s on my last CVO, deep idle, loud when getting on it, but mellow at 75 mph cruising.
I am going to try the Jack pot pro tour mufflers on the 12, if I do not like them I will do the fullsac 2.25 again.
13 CVO Road King Anniversary, #162
12 CVO Road Glide, White Gold Pearl / Starfire Black
11 FLHX Street Glide, Purple and black, wifes ride
09 FLSTC Heritage Teal and Antique White, wifes ride
FLSTFI Dave is offline   Reply With Quote
Old 12-26-2011, 08:23 PM   #6 (permalink)
strokerjlk's Avatar
some good options there.
I like the V&H power duals you mentioned with rush mufflers. 2.00 baffles. for these applications.
07 ULTRA
SE 120Rxtra
Old 01-29-2012, 05:51 AM   #7 (permalink)
Claude
I have a 2012 CVO Ultra and just got the engine upgraded with TW400 cam, new valves, roller rockers, 10.3 compression, ported intake with K&N etc...For the exhaust I went with Fullsac X pipe and SE Fatshotz mufflers. These give a deep and powerfull sound without being obnoxious.
Claude
Claude is offline   Reply With Quote
Old 01-29-2012, 06:56 AM   #8 (permalink)
tennesseecane is on a distinguished road
I've put Rush 2" duals on two different bikes, the last one was an 11' Ultra Limited and they were just right. Not too loud unless your getting on it. I do however use the helmet headset for all music.
tennesseecane is offline   Reply With Quote
Old 02-03-2012, 09:25 AM   #9 (permalink)
alremc's Avatar
alremc
ALot of CVO's putting on Fullsac's system and are happy with it which is why i will eventually go with that when i get over the down payment headache!!
Frank
2012 CVO Ultra Classic Electric Orange/Black Diamond
2000 Ultra Classic
alremc is offline   Reply With Quote
Old 02-16-2012, 03:32 PM   #10 (permalink)
speedmike is on a distinguished road
Any suggestions?
I have had a lot of experience from the Vance and Hines Power Duels with the high outputs
speedmike is offline   Reply With Quote
Old 02-16-2012, 03:39 PM   #11 (permalink)
XLIII
MegaGlide's Avatar
MegaGlide is on a distinguished road
When I got tired of not being able to hear my tunes at full volume w/ HogTunes speakers, I dumped my V&H Ovals (95", 10:1 CR, 37g cams) and went with the SE FatShotz on my V&H Dresser Duals.
Good sound, not obnoxious at cruise.
Dave
Snarkiness without knowledge is, well, just sad, really.
Sherlyn Popelka DUI, Aggravated Assault, Fugitive Arrest Reports HERE:
http://www.sherlynpopelka.net/
MegaGlide is offline   Reply With Quote
Old 02-16-2012, 04:34 PM   #12 (permalink)
redmanmbz is on a distinguished road
Check out - http://www.rbracing-rsr.com/products.htm
Not the cheapest, but, you get what you apy for.
redmanmbz is offline   Reply With Quote
Old 02-16-2012, 06:05 PM   #13 (permalink)
guydoc77's Avatar
guydoc77 is on a distinguished road
Hmmm. Might want to check out a couple recent threads on the forum here on RB.
2008 Road Glide
Phoenix Customs Bagger Brace
Glide Pro
Clearview windshield
107
CP flat tops
R&R Stage 3 heads, .030 gasket, 82cc chambers
Trued, welded, and balanced crank by Hyperformance
TMan 590 cams
SE AC
HPI 54mm TB
Supermeg with open cap and 15 discs
TTS tune by BVBob
2003 Indian Scout Deluxe
Aspen White (got it for my wife)
S&S "SuperStock" 88"
12" apes
Scary fast!
guydoc77 is offline   Reply With Quote
Old 03-03-2012, 08:55 PM   #14 (permalink)
Texbagger is on a distinguished road
D&D Fat Cat 2 into 1, Quiet baffle or for more rumble get the louvered baffle. Get the performance baffle and the exhaust note will BE your music. These pipes have a deep rumble and in my opine sound the way a Harley should.
Texbagger is offline   Reply With Quote
Old 05-25-2012, 12:29 PM   #15 (permalink)
billm67 is on a distinguished road
Here's another vote for a 2 into 1. I have the Vance & Hines Pro Pipe on mine. I can hear the stereo no problem and it makes a ton of usable power. It also has a very throaty sound. They can be found on the net for right arounf $500 which is not bad considering it is a full exhaust with full coverage shields.
billm67 is offline   Reply With Quote
