T man tw625 cam : V-Twin Forum: Harley Davidson Forums
Old 02-24-2011, 09:14 PM   #1 (permalink)
jtm motorcycle is on a distinguished road
T man tw625 cam
After running woods cams the tw7 h in two cvo one with compression one with out.I decided I did not like woods cams, way to noisey and not that much power gain. I installed the t man 625 cam with no other work to the engine, this is what I WAS LOOKING FOR great power from 2000 to 6000 plenty of low end torque. if you have a cvo and want a bolt in cam this is the cam to run.
jtm motorcycle is offline   Reply With Quote
Old 03-09-2011, 06:01 PM   #2 (permalink)
neversatisfiedI is on a distinguished road
Did you change exhaust or add a tuner? Did you have it dyno tuned? what did it produce?
neversatisfiedI is offline   Reply With Quote
Old 03-10-2011, 08:55 PM   #3 (permalink)
Yes I am running the arlen ness big sucker SERT stock headers with cat removed tuned at cox's harley davidson 105 hp 111 tq this is alot less than T man said I would get but he said I needed a 2 into 1 exhaust
Old 03-11-2011, 06:12 PM   #4 (permalink)
OrangeGlide is on a distinguished road
Did you use the 625 or was it the 525? I didn't think the 625 was a bolt in cam with stock springs.
OrangeGlide is offline   Reply With Quote
Old 03-23-2011, 09:01 PM   #5 (permalink)
Yes it is a 625 lift bolt in on a 110
Harley will not tell you this will work but T man performance reccomended these and I love them very quiet cam and great performance, I need to up compression to 10.5 but That willcome later. I am going to have heads cut and done by T Man, but he is so busy right now I am going to wait til april where I can get them back in abou a week. I will post numbers when complete.
Old 05-01-2011, 06:55 AM   #6 (permalink)
se120rx is on a distinguished road
Putting them cams in a se103 right now, pulled out a set of s&s 625. i did some home work they say T-man 625 are wayyyy better. Let you know soon!
se120rx is offline   Reply With Quote
Old 05-02-2011, 07:32 PM   #7 (permalink)
Hemrick performance heads
2009 roadglide S.E. 110 c.i. arlen ness big sucker,sert,vance&hines pro pipe, Tman 625 cams.head work by Hemrick performance,Tuned at Coxs Harley Davidson by Brad 114 hp 121 tq great tq curve 2000 rpm over 100 121 at 4000 This CVO feels great.
