flat tops, IIRC 1.90 intake, 1.58 exhaust. chambers are around 88cc. this is from memory, so it probably aint right, but its close. the 253 cam makes it a dog. again IIRC, last one i checked, compression was around 9.2. bottom line is to make one run, you have to work heads, raise compression and install different cams.
