Bub Enterprises
Motorcycle-CommunicationCustom DynamicsJekillandHyde.euBikeBanditLeslie Kay'sFuel Moto
MBO Enterprises
Old 06-17-2009, 04:41 PM   #1 (permalink)
hbmc's Avatar
for a lack of finding a better place to post this I made a tool and thought to share
I ended up tearing the gear set out and at 7pm I realized a puller and press was going to be needed so I made this one for about 6 bucks don't laugh it works good and smooth
http://i656.photobucket.com/albums/u...deofpuller.jpg
here is a couple different views of it, it is reversible using it on one side will pull it into the bearing as shown in pics and I am sorry I did not take a pic of removal but if you use it on the other side and flip the block to 12 and 6 position flat side against tranny case it will pull it fine with no damage to cases.
http://i656.photobucket.com/albums/u...erhomemade.jpg
http://i656.photobucket.com/albums/u...ckofpuller.jpg
next pics show using it * notice I used the old bearing to support the pressure exerted from the puller by placing the old bearing on top of newly installed one also I used a piece of hose to protect the needle bearings when I slid the thread thru the gear (see pics)
http://i656.photobucket.com/albums/u...singmainin.jpg
http://i656.photobucket.com/albums/u...tingpuller.jpg
*notice the old bearing here being used****
http://i656.photobucket.com/albums/u...llingmain1.jpg
http://i656.photobucket.com/albums/u...llingmain2.jpg
http://i656.photobucket.com/albums/u...llingmain3.jpg
http://i656.photobucket.com/albums/u...llingmain4.jpg
I hope these helps as I enjoy the help I get on here too!
1991 flstf 'fat-boy
2-1 White "E-pipe"
29 tooth Andrews pully
Old 06-17-2009, 07:16 PM   #2 (permalink)
Huge Member
fourstar is on a distinguished road
I couldn't get anything with any of the links.
Can you hear me now?
fourstar is offline   Reply With Quote
Old 06-17-2009, 09:17 PM   #3 (permalink)
NHFree1's Avatar
NHFree1 is on a distinguished road
Me too...bad links.
"To sit back hoping that someday, some way, someone will make things right is to go on feeding the crocodile, hoping he will eat you last - but eat you he will." – Ronald Reagan
NHFree1 is offline   Reply With Quote
Old 06-18-2009, 06:09 AM   #4 (permalink)
hbmc's Avatar
Exclamation
try again.... sometimes in cut and paste you get corrupt paths/
1991 flstf 'fat-boy
2-1 White "E-pipe"
Old 06-18-2009, 03:26 PM   #5 (permalink)
Deuce Bigelow's Avatar
Deuce Bigelow is on a distinguished road
Thanks for sharing, but this isn't CVO related..... It's EVO related! LOL
a better place to post this would be in the "Technical Discussion Forums"......
2007 "Canyon Copper" FXSTSSE
TTS MasterTune
Rinehart "Cross-Back" exhaust
Deuce Bigelow is offline   Reply With Quote
