01-05-2009, 08:01 PM
fly by wire throttle
has anyone had poor throttle responce, I have 2009 serg with 257 cams and rineharts, with a master tune, and can not crack throttle even a little with out it falling on face, any sugestons? thanks
01-05-2009, 11:22 PM
Moneygreen
Well let's see were we should start!!!!!!How much comp are you running with that cam?Who did the Tune? Your Rineharts are not the best pipe for tq.I don't think it's your throttle response,it's your package of parts & your tune!!!!!
Craig G.
01-05-2009, 11:35 PM
Stock 09 RG here, no hesitation at all. I'd agree with the poster above.
01-06-2009, 09:26 AM
the motor is bone stock, except for cam, 9.3 comp. bruce @ horse power express in camble did the tune, he is a very good tuner
01-06-2009, 11:33 AM
Moneygreen
That's your problem!!!You not running enough comp for the SE 257!! It has a 48 intake close & 9.3 is not enough.Your tuner should have told you that,so it obvious he's not as good as you think he is!!! Up the comp to around 10.5 or 10.8 and it will run like raped ape.What else did you do to the motor??? Did you address the lower end crank????
Craig G.
01-06-2009, 12:20 PM
so what cams do you recomend? with out going way into the motor, i would like to keep my waranty, thats why i put harley cams in it. thanks
01-06-2009, 12:47 PM
Rebel Son
Ya wanna keep your warranty?
A non-HD technician opened up the cam chest, exposing the interior to what ever is in his shop: metal shavings, etc...
Then tuned the ECM with a non-Harley tuner. (BTW - I like the TTS MasterTune)
Most dealers may cover the bike if they did the work themselves. Don't get me wrong, I wish you all the luck.
--m
2004 Night Train
2009 Street Glide
01-06-2009, 01:06 PM
Don't the new bikes come with se255s? If so, you should've left those in there. They quit a little early, but it'd make a hell of a hole shot! You might have also gone with se203 or se204.
2005 Fat Boy
95", se251 cams
HTCC CNC Heads
Heavy Breather AC
SE Pro II Slip-ons
01-06-2009, 01:56 PM
the 257 cam's made a big differance 103hp-122tq just not happy with throttle responce (not under load) mabey i need a better tune. thanks for all the reply's
01-06-2009, 02:29 PM
F$ck Google ads
The 257 without further modifications is dead wrong for this bike. Way too heavy bike to overcome the very low dynamic compression in main driving range of the engine.
I ran this cam (Andrews 67G, same thing) in my 107 FXST at 10.7 comp with a 2 deg advance key. This thing pulled everywhere from 2000-5500 rpm, but there were other extensive mods.
A woods 6H or similar comes to mind, but they need comp as well.
Are you worried about the warranty?
2008 Ultra dark blue pearl
BigBoyz ported street heads
103" SE FT
0.030 Cometic HG
Woods TW 6
V&H Monster Ovals
SE ventilator a/c
TTS
SE compensator
SE race clutch
VPC 92 T
Magura hydraulic clutch
BaggerBrace stabilizer
Full floater front discs
After Douglas Adams RIP
01-06-2009, 06:55 PM
Moneygreen
You can keep the cams if you want,just raise the comp up to about 10.5 or 10.8 to 1!!!!It will wake the bike up.What are you looking for tq or hp??? Or a combo of both?????
Craig G.
01-07-2009, 10:29 AM
the bike makes good enough power for my riding, and realy don't want to change pistons, then i should change the crank or beef up bottom end this not want i want to do, my complaint right now is not being able to flash the throttle with clutch in, it stumbles, is it just the tune? thanks
01-07-2009, 10:42 AM
Could be. See if your tuner will put it back on and look for the stumble.
Have you/he messed with the throttle progressivity settings?
Where exactly is the stumble? Under what conditions?
www.bigboyzheadporting.com
Big Boyz Street Heads
207-242-8374 Cell Phone
207-621-8089 Port/Dyno Shop
01-07-2009, 10:46 AM
Moneygreen
It could be just the tune.You don't necessarily have to change pistons to raise comp.You could change the head gasket or shave the head, or both!!!I would start with having the bike re-tuned!!!!
Craig G.
01-07-2009, 11:55 AM
thanks, i will take it back to the tuner and see what he can do, as far as a stumble goes,
i am talking about reving it up
