Well, here's my opinion since i have installed 3 different cams in 3 different CVO 103's.
SS570. Not bad, quiet, eaiser starting, but builds power late after 3200 rpms.
Redshift 575..Not bad and felt similar to the SS570 but felt it kicked in a bit sooner.
Woods TW6..the winner.Power kicks in instant(or just about), bike start easier and is getting better mileage, low and midrange tq and more power overall. It doesn't feel like it looses steam until over 5k...the first 2 cams may show more horsepower not torque on the dyno, but dont let it fool you.
All the cams will feel better, but the tw6 might be the best choice IMHO.
Now...here might be your deal breaker. If you want tq at the low an RPM the RH duals will kill whatever is gained by a cam swap. If you were to go to a TW6 wood's cam and a fatcat you will be a very happy man!
Now, if you really want a kick in the pants ride, send those heads out to be ported. Hillside did an amazing job on this build. This bike for a 10 to 1 compression 103 with a 510 lift cam is beating out many a bigger build and also lighter bikes.
Dont forget a GOOD tune when done.
CHECK OUT THIS LINK FOR MORE INFO...
Axtell 117 cyls and pistons
Mikuni HSR48
S+S Super D manifold
Black Boarzilla
