BikeBanditFuel MotoRRcycles.comSportbikeTrackGear
Motorcycle.comCustom DynamicsPro PadProCharger.comJardineProducts.com
Cycle Gear
Old 07-09-2007, 12:42 PM   #1 (permalink)
hogger911 is on a distinguished road
S.E. 110 HAngs at 5000/5600 no power??
That title should read 5500/5600 RPMs BTW my bike is a 2007 Street Glide with the 110 S.E. Dealer installed kit...
Guys I have a 110 with S.E. Roller Rocker arms/Lifters High flow filter , Vance and Hines True Duals and Rineharts 2 1/4 performance mufflers...
I have the latest april 110 map with the Auto tune etc...
My plm. is I can get it to go through the gears 1,2,3,4, to 6100 no plms. smooth as silk....
when I shift into 5 top speed is 119 mph and the RPMs go to around 5500 /5600 and thats it it won`t pull any farther shift into 6 same deal hangs at same rpm and top speed remains about 119 mph No dynos where I am at and Rev. limiter is set at 6200???
I know this bike should atleast hit 125 mph if not more like 128 mph or so...
What do ya all think may be my problem.. as I said it is nice and smooth to there no pinging etc etc..Btw.. Wheels are set at 42500 in program correct.
Any thoughts Kind of piss that this is all its got Thanks alot...
Chris
hogger911 is offline   Reply With Quote
Old 07-09-2007, 09:25 PM   #2 (permalink)
WoW...! Over 30 Views and not one post?
Old 07-09-2007, 10:00 PM   #3 (permalink)
PR3VS56's Avatar
PR3VS56 is on a distinguished road
My guess is speed limited at 119.
'09 FLTRI, Vivid Black, ABS.
Pri: Amsoil Syn ATF. Trans: Redline Heavy ShockProof. Crank: Redline 20W50HD
'05 FLTRI, totaled 10/17/08.
105tq/107hp
'00 FLHRCI, sold.
Proverbs 3:5-6
Fruit of the Spirit
PR3VS56 is offline   Reply With Quote
Old 07-10-2007, 06:16 AM   #4 (permalink)
my guess is running out of power to pull those gears. spin forth up to redline if you can, it should be over 120. then go to 6th, if bike slows down, its a lack of power.
if you cant hit the limiter in 4th, something is wrong, or serious lack of power.
Old 07-10-2007, 12:04 PM   #5 (permalink)
1,2,3,4 all go to around 6000 nor plms shift into 5 maintains 56oo rpms and 119 mph..Same as shifting into 6th gear just maintains the same rpms and speed thats it plugs are on the white side as all 2007 models are Thinking I have to richen it up and or timing any thoughts??
Old 07-10-2007, 02:13 PM   #6 (permalink)
i have seen a couple of the newest maps for tmax that are lean in mid and upper ranges. last one i loaded showed a target of 13.8 and was leaner in some areas. wouldnt hurt to load one of the older maps with a tartget of 13.1 just to see.
Old 07-10-2007, 03:05 PM   #7 (permalink)
F$ck Google ads
ViennaHog's Avatar
Don't understand. If the bike hit 5500 in 5th at 119mph, how can it hit same rpm/speed in 6th?
If you have stock overall gearing you should hit 129 mph at 5500 in 5th and 152 in 6th. Something doesn't compute. Speedo kaput?
2008 Ultra dark blue pearl
BigBoyz ported street heads
103" SE FT
0.030 Cometic HG
Woods TW 6
V&H Monster Ovals
SE ventilator a/c
TTS
SE compensator
SE race clutch
VPC 92 T
Magura hydraulic clutch
BaggerBrace stabilizer
Full floater front discs
After Douglas Adams RIP
ViennaHog is offline   Reply With Quote
Old 07-11-2007, 07:18 AM   #8 (permalink)
I run the gears up in 1,2,3,4 to 6000 and at 4 it is at or around 199, 117 or so shift into 5 same rpms now and 119 shift into 6 same rpms and same 119 mph ...
After shifting into 5 from 6000 rpms in 4th the revs drop to around 5500 rpm and the speed stays at 119 and won`t rev higher and sift into 6 th the same thing stays around 5500,56000 rpms and smae 119 mph doesn`t matter if on a flat road or down a small slope..???
Old 07-11-2007, 08:20 AM   #9 (permalink)
VH makes a good point, as i was concentrating on a power issue, i missed the realationship of speed/rpm.
that said, and this is a long shot because of the exact rpm in 5th and sixth, but possible clutch slip? and lack of power?
Old 07-11-2007, 08:26 AM   #10 (permalink)
PR3VS56's Avatar
Or speedo off. If the clutch were slipping the R's would rise in 6th. Weird.
105tq/107hp
'00 FLHRCI, sold.
Proverbs 3:5-6
Fruit of the Spirit
Old 07-11-2007, 12:05 PM   #11 (permalink)
thats one reason for my disclaimer, but i dont think that motor will pull 5500 rpm in sixth gear. it would surprise me if it would pull 5500 in fifth.
800+ lb bike with what? 95-100 tq?
Old 07-11-2007, 12:06 PM   #12 (permalink)
F$ck Google ads
ViennaHog's Avatar
Get this thing on a dyno and verify speedo/tach readings as a starting point. A few runs in 5th/6th gear under 50% or more load will tell you the story about clutch slippage etc.
No point in trying to solve it over the internt with no data/facts
103" SE FT
0.030 Cometic HG
Woods TW 6
V&H Monster Ovals
SE ventilator a/c
TTS
SE compensator
SE race clutch
VPC 92 T
Old 07-11-2007, 12:55 PM   #13 (permalink)
Come on guys.... Clutch slipage..... No way...
plus going down a small slope Clucth slipage don`t come into the picture here its either fuel or timing...???
or just one fat pig with no top end power...
Old 07-11-2007, 03:16 PM   #14 (permalink)
degressing to VH. another great point vienna.
Old 07-13-2007, 01:38 PM   #15 (permalink)
Iron Will
Hillside's Avatar
Power/gear
Chris
you don't have enough to pull that long gear.
Either more power or more gear.
By gearing down,believe it or not, you will probably be able to aggressively pull up to a higher mph.
