L.E.D taillight prob : V-Twin Forum: Harley Davidson Forums
Old 11-26-2012, 01:23 PM   #1 (permalink)
evobob71 wants to know Dino or Syn?
I have the HD rear led tail light on my bike the only light that works is the license plate light no tail/brake light anyone with any known ledge with these would be helpfull
evobob71 is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 02:14 PM   #2 (permalink)
alexlivetoride's Avatar
alexlivetoride wants to know Dino or Syn?
Is it new installed? Was it working before? Need more info
alexlivetoride is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 03:21 PM   #3 (permalink)
Yes it was working before, I checked for power at the plug right before light and it was there
Old 11-26-2012, 04:05 PM   #4 (permalink)
The only possibility will be between the socket and the light then.
Old 11-27-2012, 03:46 AM   #5 (permalink)
The Anti-RUB
petrock's Avatar
Thats not entirely correct. You need a good ground to complete the circuit. Without it the lights won't work.
How did you check for voltage? Did you check it with the tail light unplugged? Where was your multi/volt-meter leads connected? 2, 3, 4 or 5 wires going into the tail light plug? I ask these questions because it makes a difference in the reading, there meaning and what to check next.
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
Old 11-27-2012, 10:41 AM   #6 (permalink)
FYI The tail light ground is in the socket not body ground, what I said is to check all 3 power, running, brake and ground at the socket. He did mention the license plate light works, the ground is good then. Sorry if I confuse ppl
