Auto Cancel Turn signal problem : V-Twin Forum: Harley Davidson Forums
Old 11-05-2012, 07:01 PM   #1 (permalink)
RustyG is reading this now saying WTF is this?
The auto cancel feature of the turn signals has stopped working on my 2002 Road King Classic. Everything else seems to work properly.
The signals do not turn off after a turn like they used to do.
Anyone care to elaborate as to where the problem is. On my V-ROd it points to the HFSM as being bad. Don't know enough about the RK's electrical to hazard a guess.
Regards,
John
Everything is JMHO. Accuracy is not assured.
Originally Posted by Mark Twain
The more I know about people the better I like my dog. -
2007 VRSCX 0461 / 1400
2003 VRSCA Gone but not forgotten.
RustyG is offline   Reply With Quote Quick reply to this message
Old 11-05-2012, 08:27 PM   #2 (permalink)
monkeyboy's Avatar
monkeyboy wants to know Dino or Syn?
You're going to have to bone up on your electrical ability. If I had to hazard a guess, I'd say you should start looking at your TSM (or TSSM if you have factory security) or a bank angle sensor.
The cost of living hasn't affected its popularity
monkeyboy is offline   Reply With Quote Quick reply to this message
Old 11-05-2012, 08:59 PM   #3 (permalink)
speedfoos's Avatar
speedfoos wants to know Dino or Syn?
It's probably out of fluid.
| PHOTOS |
speedfoos is offline   Reply With Quote Quick reply to this message
Old 11-06-2012, 08:00 AM   #4 (permalink)
self banned
Road King Cole's Avatar
Road King Cole is still riding a stock bike Road King Cole is still riding a stock bike Road King Cole is still riding a stock bike
Is your speedometer still working?
The module needs to sense an increase in speed to turn off.
rkc
2016 Ride of the Year Winner!
Road King Cole is offline   Reply With Quote Quick reply to this message
Old 11-06-2012, 11:19 AM   #5 (permalink)
fourhour's Avatar
fourhour wants to know Dino or Syn?
rkc
I agree. Check your speed sensor. You may have to clean the magnetized pieces of metal stuck to it. It is accessible on top of the tranny on Softails. I assume it's probably similar on a RK. About $60 or so to replace if necessary.
"Let the world know you as you are, not as you think you should be, because sooner or later, if you are posing, you will forget the pose, and then where are you?" - Fanny Brice, American actress and singer (1891-1951)
fourhour is offline   Reply With Quote Quick reply to this message
Old 11-06-2012, 06:25 PM   #6 (permalink)
Speedo works just fine.
Speedfoos the blinker fluid was replaced 5K miles ago at the last service interval.
Regards,
John
Old 11-06-2012, 06:34 PM   #7 (permalink)
road_king's Avatar
road_king wants to know Dino or Syn?
Based on the info provided and symtoms it is likely you have a TSSM issue.
road_king is offline   Reply With Quote Quick reply to this message
Old 11-07-2012, 09:10 AM   #8 (permalink)
self banned
(unless of course the wire or connection is bad to the TSSM. I think the wire was orange\white on mine.)
Albeit we didn't hear if the blinker fluid was dino or synthetic. You know synthetic blinker fluid is too slippery.
and if you have the security feature, it may be an expensive fix... Myself I never liked\trusted the auto turn off so I disconnected the speed sensor and turn them off manually.
rkc
Old 11-07-2012, 01:41 PM   #9 (permalink)
webco2 wants to know Dino or Syn?
You have to run the RED Blinker fluid. The green is crap..
webco2 is offline   Reply With Quote Quick reply to this message
Old 11-07-2012, 02:30 PM   #10 (permalink)
fourhour's Avatar
Have you ever seen it move erratically from zero to 120? When that happens it will sometime quit all together, and then go back to normal operation. I would again suggest you remove the speedo sensor, wipe it clean of metallic filings and reinstall it. You may get some more life out of it. I had to replace mine about 5 y/o on my 2002 Deuce.
Old 11-07-2012, 02:36 PM   #11 (permalink)
self banned
I also had to replace mine a few years back too. Cleaning didn't help. I remember it wasn't expensive and not that hard to do. Perhaps that is a cheaper thing to try before buying a new TSSM module...
rkc
Old 11-07-2012, 06:20 PM   #12 (permalink)
Have no other problems. Just the automatic cancel does not work. I will clean out the speed sensor though as a precaution and see what happens.
Manual says the auto cancel happens after a 45 turn or 20 seconds at constant speed. The 20 seconds part works. The 45 turn does not. Even tried a 45 lean but no luck. Sounds to me that the BAS (Bank Angle Sensor) is not working or is stuck.
Regards,
John
Old 11-08-2012, 07:26 PM   #13 (permalink)
road_king's Avatar
fyi..the Bank Angle sensor is integrated in the TSM/TSSM on your 2002 RKC
Old 11-12-2012, 06:01 PM   #14 (permalink)
trackrat wants to know Dino or Syn?
i had the same problem. put on a new h-d tsm, cost me around 150.00. worked for about a week. i also did the speed sensor cleaning , until that quit working. replaced the sensor and that fixed my problem. got my sensor from jireh cycles for around 35.00 and about 10.00 to ship
trackrat is offline   Reply With Quote Quick reply to this message
Old 11-12-2012, 06:31 PM   #15 (permalink)
I think I will take the tssm off and drop it on the ground a few times. Maybe that will loosen things up. Hate to buy a new one. Pain in the Azz to replace a tssm.
Regards,
John
