Compression ratio on a 103ci : V-Twin Forum: Harley Davidson Forums
Old 11-02-2012, 11:47 AM   #1 (permalink)
alexlivetoride's Avatar
alexlivetoride wants to know Dino or Syn?
I am going to do a 96-103ci conversion, SE flat top pistons, does anyone know the compression ratio? If it is less than 10:1 I will use stock head gasket. Thanks!
alexlivetoride is offline   Reply With Quote Quick reply to this message
Old 11-02-2012, 01:11 PM   #2 (permalink)
monkeyboy's Avatar
monkeyboy wants to know Dino or Syn?
The piston is the main factor in determining compression so what ever they advertise the piston as, it'll probably land in that area. There are some other things that can change compression ie: heads, head gaskets, etc.
The cost of living hasn't affected its popularity
monkeyboy is offline   Reply With Quote Quick reply to this message
Old 11-03-2012, 10:41 AM   #3 (permalink)
These are SE flat top pistons, some ppl said 9.5:1, the SE catalogue didn't specify. Should I get the SE high compression head gasket to be safe?
Old 11-03-2012, 11:28 AM   #4 (permalink)
strokerjlk's Avatar
Use a .040 or .030 gasket.
What cam you gonna use?
07 ULTRA
AMRA
SE 218
DR 218
Old 11-03-2012, 12:06 PM   #5 (permalink)
Thundermug's Avatar
Thundermug wants to know Dino or Syn?
SOMETIMES....Some people need to pay someone to do the work.......just sayin.....
The Doctor said I have ADD but I don't think I...Hey, look a chicken!
2008 XL1200C
2011 FLHTK
Thundermug is offline   Reply With Quote Quick reply to this message
Old 11-03-2012, 01:49 PM   #6 (permalink)
monkeyboy's Avatar
I think I read another post by the OP that said, in addition to getting some warranty work done to the bottom end, he was going to do a big bore kit. Sounded like he is having a bit of trouble with the dealer that's doing the work and he's trying to get his shopping list filled.
Old 11-04-2012, 12:03 PM   #7 (permalink)
Wood TW-555 and fuelmoto PRs, thanks!
Old 11-04-2012, 12:56 PM   #8 (permalink)
strokerjlk's Avatar
If your getting a kit from Jamie , get a cometic .030
If the dealer has a .040 then that is fine also.
Just done use there .054-.060 head gaskets
07 ULTRA
AMRA
SE 218
DR 218
Old 11-04-2012, 01:39 PM   #9 (permalink)
Thanks man! I only bought the cams, PRs and Tmax autotune from Jamie, no head gaskets. Do you have the part number for the 0.040 gasket? What's the advantage of getting a thinner 0.030 gasket? More compression? If I use a thicker or thiner gasket, I assume the valve adjustment is more or less, correct?
