Ethanol fuel history - interesting - Page 3 : V-Twin Forum: Harley Davidson Forums
Old 11-06-2012, 01:03 PM   #31 (permalink)
sportcruiser wants to know Dino or Syn?
Originally Posted by webco2 View Post
The Feds figured it out, I did not!!!!!!!
Thusly the rule to increase the fuel storage and horsepower requirements for back up power generating at nuclear power plants.
10-4. It sounds like they were planning ahead for E85 (or E100).
sportcruiser is offline   Reply With Quote Quick reply to this message
Old 11-06-2012, 07:15 PM   #32 (permalink)
ForgeThe wants to know Dino or Syn?
My bike is an 01 Fatty. When I bought it had about 3000 miles (couple years ago). The owner never rode it much and just he let it sit in his garage...he also did not drain the fuel. When I drained the fuel it looked like turpintine...luckily after changing all fluids it ran great. After putting 2000 miles on it I swapped the tins. Inside the gas tank the grey coating was pealing (alot--tank started to rust inside after about a week sitting in garage). Wonder if it was the old gas or the fact he would put ethenol gas in it?
ForgeThe is offline   Reply With Quote Quick reply to this message
Old 11-07-2012, 12:43 AM   #33 (permalink)
webco2 wants to know Dino or Syn?
Ethanol falls out of suspension without constant agitation . Ethanol collects water from the air. Water causes rust. Ethanol is crap for fuel.
webco2 is offline   Reply With Quote Quick reply to this message
Old 11-07-2012, 09:19 AM   #34 (permalink)
Topgeye wants to know Dino or Syn?
I recently had the carb on my old motor home rebuilt by an old guy that has been doing it all his life. He took it apart piece by piece while I was there so he could show me what was wrong with it. When he pulled the top off the float bowl he gave me an "uh huh" and told me to look inside the bowl. It was coated with a large amount of a dry tan/gray film and the bottom had a sizable amount that had settled there. When I ask him what it was he lit into ethanol pretty hard. He said when a carb that has been running ethanol laced gas and is not run daily like my MH it does as Webco says. The ethanol falls out of suspension and the solids in it settle in places like the carb, fuel pump and gas lines that may have a bend that hangs down from the engine. He said that over a period of time when that residue gets mixed over and over it acts like sand paper inside the fuel system which can cause rubber fuel lines to deteriorate, electric fuel pumps to freeze up, filters to plug up and cause problems like mine. The rubber plunger on he accelerator pump was coated in this residue and was stuck to the inside of the bowl top cover. It had pulled free from the rod and spring and did not move when the gas pedal moved the rod up and down thus no gas in the carb. He had a vial of the residue that he had collected over the years from a lot of the carbs he has worked on. He tapped some out on his table and I moved my finger around in it and the best I can explain the texture is just a little above corn starch (not a pun) It looked sandy but felt very fine in texture. I for one love having old guys like this around that have seen it all and are willing to help and spread their wealth of knowledge. Which this old boy loved to do. These guys are dropping out fast and probably won't be replaced. He is one of the reasons I started researching our ethanol problem.
Topgeye is offline   Reply With Quote Quick reply to this message
Old 11-07-2012, 06:44 PM   #35 (permalink)
The Best Me I Can Be
Homesick's Avatar
Homesick just installed tassels Homesick just installed tassels Homesick just installed tassels Homesick just installed tassels
A mechanic at the local indy shop showed me a disassembled carb the other day. It wasn't as severe as what you describe, but that crap was in there.
Keep The Change
Reader of Ayn Rand
Inventor of the FXR Cult Secret Decoder Ring
A**hole Merit Badge winner
Missing Link Merit Badge winner
Badge of Honor winner
FXRT- Hubba Hubba
Oct '14 RotM
Homesick is offline   Reply With Quote Quick reply to this message
Old 11-08-2012, 05:19 PM   #36 (permalink)
Ethenol
That is why I try not to run it in my bike or in my old truck. NonEthenol gas also seems to get better mileage.
Old 11-08-2012, 06:11 PM   #37 (permalink)
cata5803's Avatar
cata5803 wants to know Dino or Syn?
I haven't noticed any better mileage with non ethenol fuel.. I check my mileage about eveytime I fuel.. That tells me how it's running...
2008 FLHTI Standard (29 of 200)
cata5803 is offline   Reply With Quote Quick reply to this message
Old 11-09-2012, 01:43 AM   #38 (permalink)
berserker's Avatar
berserker is still riding a stock bike berserker is still riding a stock bike berserker is still riding a stock bike
I had to reset the fuel calculator on my vehicle when I fueled up, otherwise it just keeps averaging over multiple tanks.. Of course I could use a calculator.
berserker is offline   Reply With Quote Quick reply to this message
