Oil capacity '08 96CI Dyna? : V-Twin Forum: Harley Davidson Forums
Old 04-06-2012, 01:22 PM   #1 (permalink)
Savorino wants to know Dino or Syn?
How much oil do you put in your 2008 96cubic Inch Twin cam motor for a Dyna chassis? (2.5qt, 3qt or in between?)
FYI: My first oil change, have seen 2.5qt as the capacity as well as 3qt; put 2.5 in at first but when it showed low so added the rest, wonder if it's over full now.
Savorino is offline   Reply With Quote Quick reply to this message
Old 04-07-2012, 09:36 AM   #2 (permalink)
harley-gearhead wants to know Dino or Syn?
I know for my 08 FXSTC ( 96 ci as well ), I always put 2.5 qts. in, ride enough for it to warm up, and check it again. And it always ends up being just a little shy of where I like to keep it, so I usually ad about another 1/3 of a qt. and it makes about rite, and I've never had any problems with it, doing like that, so hope this helps ya. Ride safe.
harley-gearhead is offline   Reply With Quote Quick reply to this message
Old 04-07-2012, 10:06 AM   #3 (permalink)
Yeah, Thanks, That helps.
That's what I should'a (and had planned to do) done, but I saw 3qt capacity somewhere and overfilled it. Need to get a little out.
Old 04-07-2012, 10:26 AM   #4 (permalink)
shovelmike's Avatar
shovelmike wants to know Dino or Syn?
Get a factory service manual, it will pay for itself quickly. Regarding oil level, fill to just above the "add" mark on the dipstick, go for a ride to warm it up well, then recheck. Between add and full = 1 quart, it is advisable to run about 1/2 quart low, otherwise oil may be discharged out the air filter at sustained high speeds.
This is my Granddaughter, Sky, born in February of '02. She can't walk,talk, or feed herself due to brain injury but look at that smile. It makes most of our troubles seem quite insignificant.
shovelmike is offline   Reply With Quote Quick reply to this message
Old 04-09-2012, 12:10 PM   #5 (permalink)
Thanks for the info all!
Old 04-27-2012, 09:00 AM   #6 (permalink)
peachtreeautosa's Avatar
peachtreeautosa wants to know Dino or Syn?
She's beautiful!
I'm Just Say'n
peachtreeautosa is offline   Reply With Quote Quick reply to this message
