Auto Tuners????? : V-Twin Forum: Harley Davidson Forums
Old 01-06-2011, 10:08 AM   #1 (permalink)
rahill13 wants to know Dino or Syn?
Auto Tuners?????
I'm thinking about replacing my Power Commander III with an auto tuner. I've been looking at Power Commander V with Auto Tuner and Zipper's Thunder Max. Looking for any and all information you guys might have.
Thanks,
Bobby
rahill13 is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 10:16 AM   #2 (permalink)
laserp's Avatar
laserp wants to know Dino or Syn?
Don't forget to look into the TTS Vtune
Components:
02 FLSTCI 117, Darkhorsed, Baisley Pro-Street Heads & corrected geo. roller rockers, Axtell kit 20 deg. rev. dome pistons 11.5:1, HPI 55/58mm MaxFlow tb, Tman TR-662-2 & 3 stage pump, Boarzilla, Barnett Scorpion clutch, Jag 10 row oil cooler, tuned w/ Twin Scan II+/WEGO IIID
10 Ultra Limited 103, Andrews 54 cam, SEAC mod breather, Bigboyz ported heads @10.2 comp, Jackpot 2-1-2 header and Dyno tuned muffs, TTS, tuned w/ Twin Scan II+/WEGO IIID
laserp is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 10:45 AM   #3 (permalink)
DURWOOD's Avatar
DURWOOD wants to know Dino or Syn?
Got a buddy in Florida that swears by the T-max,never ran one myself,just what I was told.
2011 Road glide Ultra
John 3:16
DURWOOD is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 11:48 AM   #4 (permalink)
155" R&R TwinCam
dog155's Avatar
dog155 wants to know Dino or Syn?
If any of these are as good as S&S IST ignition then by all means pick one up.The beauty of S&S is you can change anything in or on the motor and the ignition will adjust itself and learn the way you ride to maximise the ignition curve,all the while keeping the motor out of spark knock.
dog155 is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 11:53 AM   #5 (permalink)
TOMCENTRAL's Avatar
TOMCENTRAL wants to know Dino or Syn?
Got a buddy in Pa.The tmax drove him nutz & he sold it!Bike was tuning all over the place. BEWARE:Caution,do your home work.Everything I have read on these so called SELF tuning devises fall short of expectations.No flame intended but I think even PowerCommander come out with another tuning devise to replace the auto tune?
Again,I don't want to get into a Family Feud but check what the survey says:
Most folks are running a TTS & finding a great tuner.Regards,Tom
TOMCENTRAL is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 12:05 PM   #6 (permalink)
TIMTOOLMAN wants to know Dino or Syn?
ive had most of them pc ll, pclllr, pcv/auto tune, tmax, s.e. downloads, now using tts, The tts is my fav. so far, So much more options, u can autotune the afr's/ve tables and you can autotune the spark data using the datamaster program that is included to get the correct spark tables, Many will say you cant autotune the spark for a particular map, Yes you Can! U can change ratios for both tires and gearing changes, just click for changing injectors and cubic in changes, uses stock exh o2 sensors, dealer has them. sooooo much more, the others will get u a good tune, but not many options to customize the engines performance, Constant free software updates some others have this to, The down side to tts is its married to the ecm permanent, where others can be transferred Need i say any more?
2009 ultra
hillside 117
S&S Crank/ Timkin
hillside stage 5 2nd gen heads
woods 400-6 cams
woods directional lifters
H.P.I. 58/58 T.B. with 1.800 intake runners.
6.2 injectors
s&s p rods
woods billet rocker supports, .030 offset
Rush Wrath 2-1
S.E.cam plate S.E. H.V. oil pump
Axtell oil bypass mod
tts Tuner
doherty p/p intake modified for hillside big green air filter
S.E. compensator
30 tooth pulley
big sky dual oil cooler fans
HTCS AW/SW USN RET
TIMTOOLMAN is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 12:17 PM   #7 (permalink)
Tbones wants to know Dino or Syn?
I have the T-Max in all my bikes and have had no problems with them... No auto tune system out there will give you a 100% tune, only a good tuner and a dyno can do that no matter what tuner you are using... I'm looking at this twin tec tuner for my dresser with the pro-charger blower... I ran the Trask Turbo on my 05 V-Rod for three years and it dyno'd out at 155 hp right out the box with the map provided by Nick Trask... I might have got 160 out of it with a tuner dialing it in more but I was happy with the 155... I haven't ran the PCV with auto tune so I can't comment either way on it, I've heard good and bad on it just like T-Max... I've ran the PCIII USB, Vance & Hines Fuel Pak and the Screaming Eagle Race Tuner... I'll stick with T-Max or the daytona tuner... Here's the link for the twinteck... http://www.daytona-twintec.com/index.html
Tbones is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 01:40 PM   #8 (permalink)
Coonass Extraordinaire
beaureed445's Avatar
beaureed445 wants to know Dino or Syn?
I'm a fan of the TTS.
2007 FXST
113" Science Project- Baisley Heads, T-Man Cams, HPI t/b,
CP Piston return springs, Fatcat with high flow muffler bearings,
Amsoil synthetic blinker fluid, etc, etc, etc.......
beaureed445 is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 02:33 PM   #9 (permalink)
Tbones is right no tuner will get you 100 % tts gets you the closest, but a dyno will get you that last hidden hp and trq.
2009 ultra
hillside 117
S&S Crank/ Timkin
woods 400-6 cams
6.2 injectors
s&s p rods
Rush Wrath 2-1
tts Tuner
S.E. compensator
30 tooth pulley
HTCS AW/SW USN RET
Old 01-06-2011, 03:44 PM   #10 (permalink)
In my case with forced induction on both my dresser and v-rod, TTS doesn't fit the bill... Us boost junkies don't have a lot of options out there for tuners...
Old 01-06-2011, 03:51 PM   #11 (permalink)
Eleft36's Avatar
Eleft36 wants to know Dino or Syn?
They will all have a problem if you won't take the time to learn how to use them.
Al
Stock 110" mufflers Stock Heads Andrews 26 Cams SE103" BB Kit Zippers Cam Chain Tensioners SE Compensator Mustang Wide Touring Seat Stock Bars H.D. Oil Cooler 1990's LeatherWorks inc Saddle Bags with HD Deluxe modified guards H-D Windshield Thunder Max A/T 2005 S E Tour Pack Progressive Shocks & fork Mono Tube kit
Eleft36 is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 04:56 PM   #12 (permalink)
Ironbutt
MilesToGo's Avatar
I recently went down this road when doing my 107 build. I had a PCV installed with stage one before the build and it worked okay. I wanted to make sure i got the best tune available with the 107 so i did some research. Turns out most of the knowledgable and respected tuners recommend the TTS, so that's what i went with. The 107 build and tune posted some great numbers and it's a blast to ride, so i'm happy.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
Old 01-06-2011, 04:57 PM   #13 (permalink)
yes again tbones you are for the forced induction crowd
2009 ultra
hillside 117
S&S Crank/ Timkin
woods 400-6 cams
6.2 injectors
s&s p rods
Rush Wrath 2-1
tts Tuner
S.E. compensator
30 tooth pulley
HTCS AW/SW USN RET
Old 01-06-2011, 07:22 PM   #14 (permalink)
spelk3's Avatar
spelk3 wants to know Dino or Syn?
Dynojet is coming out with a new tuning device that flashes the ECU rather than using a piggy-back unit. The Dynojet Power Vision should be released next week. It will have two different auto tune modes, one uses the AT-100 with wide-band O2 sensors the other uses the stock narrow-band 02 sensors. http://www.fuelmotousa.com/powervision.htm
spelk3 is offline   Reply With Quote Quick reply to this message
Old 01-06-2011, 07:29 PM   #15 (permalink)
tts kinda does the similiar thing only uses oem sensors already
2009 ultra
hillside 117
S&S Crank/ Timkin
woods 400-6 cams
6.2 injectors
s&s p rods
Rush Wrath 2-1
tts Tuner
S.E. compensator
30 tooth pulley
HTCS AW/SW USN RET
