Can you bump start a fuel injected harley with a dead battery? : V-Twin Forum: Harley Davidson Forums
Old 01-27-2008, 09:21 PM   #1 (permalink)
pacaver's Avatar
pacaver wants to know Dino or Syn?
If your battery is dead will it bump start or does the fuel pump and computor need juice first
1987 FLHTC
S&S polihed 124"
Revtech 6 speed
Terry components 2kw starter
Bandit chutch
fatboy wheels
custom bars
2003 FLHTCUI
totally stock (almost)
K&N high flow air filter
Rinehart true duals
power commander III
pacaver is offline   Reply With Quote Quick reply to this message
Old 01-27-2008, 09:27 PM   #2 (permalink)
R-RatedCustoms's Avatar
R-RatedCustoms wants to know Dino or Syn?
I am pretty certain that the system needs power first because all the sensors have to "tell" the ECM when to fire the plugs.
I have witnessed about six large fellows attempt push starting a bike that was FI and nothing happened. They were done after the 10th try.
A great test would be to place a dead battery in a bike and try to coast start it down a good slope.
Has anyone else tried this?
R-RatedCustoms is offline   Reply With Quote Quick reply to this message
Old 01-27-2008, 09:31 PM   #3 (permalink)
xxxflhrci wants to know Dino or Syn?
It won't start if the battery is totally dead.
xxxflhrci is offline   Reply With Quote Quick reply to this message
Old 01-27-2008, 09:35 PM   #4 (permalink)
That is what I was thinking too.
I miss the days of kickers. Man, many times have I had a bike's battery go south with no warning and the kick start save the day. But those were bikes that were carbs, coils, points, and that's about it. There were not any ECMs telling anything. It was a simple and sometimes frustrating system that had this one life saving feature.
Old 01-27-2008, 09:36 PM   #5 (permalink)
cj21tol wants to know Dino or Syn?
I have personally bump started an 07 dyna, although the battery was not completely dead, there just wasnt enough juice to turn it over. I had to do it in third gear however.
cj21tol is offline   Reply With Quote Quick reply to this message
Old 01-27-2008, 09:52 PM   #6 (permalink)
road_king's Avatar
road_king wants to know Dino or Syn?
The biggest thing is that you need sufficient power to run the fuel pump.
road_king is offline   Reply With Quote Quick reply to this message
Old 01-27-2008, 10:30 PM   #7 (permalink)
MountainMan's Avatar
MountainMan wants to know Dino or Syn?
Even if you manage to jump start it you won't get far with a dead battery. Change out your battery every 2-3 years and you shouldn't have any problems.
Cheers,
MM
2008 FLHX - Baisley 103 cid - 10.2:1 - 97 hp - 107 lbs. torque
MountainMan is offline   Reply With Quote Quick reply to this message
Old 01-27-2008, 11:09 PM   #8 (permalink)
n2trainz's Avatar
n2trainz wants to know Dino or Syn?
Same with me...the bike wouldn't turn over, but a couple guys shoved me, and she started (I used 2nd gear).
I changed the battery that same day.
'04 Dyna Wide Glide
...with plenty of extra stuff
n2trainz is offline   Reply With Quote Quick reply to this message
Old 01-27-2008, 11:16 PM   #9 (permalink)
"Jane you ignorant slut!"
ceraaa42's Avatar
ceraaa42 wants to know Dino or Syn?
Mine was dead enough to not crank it to start. Bump start, kicked right over, check engine lamp and charging lamp came on. Took to dealer and they put in a new regulator under warranty. Don't know why this would have happened though.
Chris
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
Bagger brace
43 member
ceraaa42 is offline   Reply With Quote Quick reply to this message
Old 01-28-2008, 08:23 AM   #10 (permalink)
posttal's Avatar
posttal wants to know Dino or Syn?
You cant "bump" start a FI system if the battery is TOTALLY dead..0 volts as would happen if you left something on or had a short.But you can bump start a very low battery.You just have to have a little in the battery to power the ECM and pump as mentioned.
And just a reminder to guys with older tourers..check to see if your regulator plug has been moved to the updated position.This mainly applies to the early
TC88's that had the plug mounted low and it filled with water that wicked into the stator and shorted it out giving you a intermitent no charge untill it finally totally burns out.Newer tourers were all updated from the factory.
Just my 2 cents worth
Posttal AKA Ralph
posttal is offline   Reply With Quote Quick reply to this message
Old 01-28-2008, 03:15 PM   #11 (permalink)
Highly Seasoned Rider!
newultraclassic's Avatar
newultraclassic wants to know Dino or Syn?
That's the main point. No fuel pump at the initial point will probably prevent it from starting. You need to have a signal that the pressure is up before the machine will start. I'll go a bit farther to say that it's probably not a good idea to do anything wih a bike that has a TOTALLY dead battery. Good solid voltage is the best for your system.
My 2 cents.
newultraclassic is offline   Reply With Quote Quick reply to this message
Old 01-30-2008, 06:59 AM   #12 (permalink)
155" R&R TwinCam
dog155's Avatar
dog155 wants to know Dino or Syn?
I was told at the Moco that EFI needs at least 9 volts at the battery for the motor to run.Of course without a voltmeter you would never know that.
dog155 is offline   Reply With Quote Quick reply to this message
Old 01-30-2008, 07:42 AM   #13 (permalink)
That sounds about right. I know when my voltmeter on the fairing gets down to about 9 the fuel pump sounds sloooooow and it may or may not crank.
Old 01-30-2008, 08:54 AM   #14 (permalink)
Flying low
DBotkin's Avatar
DBotkin wants to know Dino or Syn?
Chris
If the regulator fails, it won't charge the battery, so the battery will die.
100th Anniversary Ultra Classic
95" - Andrews TW26a - SE slip-ons
'55 Vespa VL1 chase vehicle, 150 CC of screaming 2-stroke madness!
Free, personalized travel maps at mytriplogs.com
DBotkin is offline   Reply With Quote Quick reply to this message
Old 01-30-2008, 05:10 PM   #15 (permalink)
scootertramp's Avatar
scootertramp wants to know Dino or Syn?
That's why I always carry a small set of jumper cables in my coat. I could carry them in my saddlebag but none of my other bikkes have saddle bags. Just small tool pouches. And sure as sh*t I'd need em and they'd be on the land yacht! Man those things have saved many of my friends over the years. Just some 12 guage wire with alligator clips.
scootertramp is offline   Reply With Quote Quick reply to this message
