Sudden loss of clutch
OK Fellas heres one for you all,
I was riding my 86 FXR and all was fine. Poof grabed my clutch lever to down shift and suddenly my lever came all the way back to the handlebar. Pulled over and had to adjust my clutch all the way out(take up slack at the adjuster) to get hte clutch to disengage so I could shift. Got home took off cable looks fine. Adjusted the clutch rod on the basket, and re installed the cable. It seemed to be fine. I adjusted the adjuster to take up the slack at the handle and all worked fine. OK, then I headed out to test drive. Perfect.
Took off out to the country on Sunday and got about 35 miles from home and when I had to down shift due to a slower moving truck in front of me, poof no clutch again. Lever comes all the way back to the handlebar. Had to adjust all the way out again to take up the slack and got my clutch back. Made it home with no problem but now I am afraid to take it out and don't know what could be causing the problem.. The cable looks good and does not seem to be broken or stretched. Got any insight or possible reasons for this mystery.
