I have two Ultima starters. The 2.0kw works except for the big reduction gear is busted in half. When this happened I called "ultima" and they didn't sell parts. Yes they do come with a warranty, but you have to fill out the card. I went to the 2.4 and compression releases, and it seems to work good. Every now and again it grinds, and I just put the bike in gear rock it foward a bit and try again. That always works. Might wanna check the jackshaft inner primary bushing and big coupler, if that is binding, then you will wear the starter clutch out, and possibly break things.
