The "arc" welding is normal, that is from 300 amps touch soft metal. Once you stop getting the starter to turn, then that washer is probably worn out. One other thing to check/change, is the the starter clutch, which is can sound like a chattering noise. If that has gonna out, then that motor is not going to turn over. You can get a heavy duty starter clutch for fairly cheap (60 bucks) and that might fix your problem. Just pull that starter off, take the reduction gear pad off and there it is. Right where the splines go into the jackshaft assembly. Press it or tap it out, put the new one in. Make sure that the splined coupler that is in the inner primary (the 1in round guy) is not chewed up. If it is, it will cause binding, which will smoke check the starter clutch.
