Progressive Insurance
ArnottAirRideMotorcycle.com Classifieds!EagleRiderSportbikeTrackGearBikeBanditCheapCycleParts.comSpringfield ArmoryKomodoGear.comExtreme Custom EngravingRosa's CycleMean City CyclesAdvanstarMotorcycleShows
Old 07-21-2008, 02:52 PM   #1 (permalink)
cpcfab is on a distinguished road
pumping out oil
I just aquired an 81 fxw and when I start it oil starts running out of the overflow tube and the primary is drowning. Is there a check valve that is sticking somewhere?
cpcfab is offline   Reply With Quote
Old 07-22-2008, 07:09 PM   #2 (permalink)
Homesick's Avatar
Homesick is on a distinguished road
Man, this section is FXR specific. You might have better luck in the pre-EVO section. Good luck.
Keep the Change
Homesick is offline   Reply With Quote
Old 07-23-2008, 01:19 PM   #3 (permalink)
You have a manual?? Buy one . There is a check ball and spring in the oil pump and your bike can leak oil back into the engine case. You check with out running??? and refill tank then start bike and to much oil ,got to go some where. There are ways to fix. Has beencoverd in mags and sites. It is not hard but might go to a shovel head shop in your area to help. You might just replace the ball and spring and (fix) the problem. It does involve laping in the ball seat by epoxy'n the old ball to a old push rod and use'n a drill and lapp'n compound to make the seat rite.
Old 07-23-2008, 01:23 PM   #4 (permalink)
springer-'s Avatar
Or you can check out this link .... http://www.v-twinforum.com/forums/ev...ve-repair.html
A factory service manual is a MUST
207-242-8374 Cell Phone
207-621-8089 Port Shop/Dyno Shop
springer- is online now   Reply With Quote
Old 07-23-2008, 03:56 PM   #5 (permalink)
chengdave2003's Avatar
chengdave2003 is on a distinguished road
pumping out oil
On my 79 Lowrider it started doing that soon after I changed all the hoses on the oil pump. I don't remember which one, but I eventually found one going to the back of my inner primary was loose. When I tightened it up, no more oil out the vent hose....
Someone had mentioned the check valve spring was getting sprung, but even after checking it, no go. It was the hose on back of the inner primary.....
Dave
MY PICS
chengdave2003 is offline   Reply With Quote
