Progressive Insurance
Extreme Custom Engraving360 Brake CompanySpringfield ArmoryWheeldock.comTech N' Cycle GearMotorcycle.com Classifieds!OriginalBikeSpirits.comMean City CyclesProCharger.comStoneyStraps.comEagleRider
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > V-Twin Performance Forums > Exhaust Discussions (aftermarket/OEM)
MetalArts
Old 11-23-2008, 02:48 PM   #1 (permalink)
Mother's Avatar
Mother is on a distinguished road
RB Racing LSR 2into1(not pro stock)..
On a 100+ hp motor how much louder than a thunderheader are they??? Anybody dyno these pipes back to back? I will be this spring if the budget allows.
95" new dyno sheet soon 10.65:1cr
S&S 'E' bored booster thunderjet high flow a/c
S&S big bore pistons w/5.3cc dome
SE roller rockers & rocker support
Fueling cam plate, oil pump, & 'B' lifters w/limiters
Leineweber .603" gear drive cams &springs
Shortblock Charlie ported heads 250cfm@28in water
TwinTec ignition
Rivera Pro-Clutch
Thunderheader
3.37's
Pirelli tires
Mother is offline   Reply With Quote
Old 11-23-2008, 04:25 PM   #2 (permalink)
thundercatken is on a distinguished road
Louder??? I've had both ... I don't think the RB Pipes are any louder ... different ... but under full power, both are loud. I have the LSR with the "Turn Down" exhaust, and with the exhaust directed straight to the ground, it "Seems" a bit quieter when puttering around town(2000-2500 RPM) ... Better for sneaking into the neighborhood at night.
Ken M
2003 FXDWG
When opening your mind to new ideas, don't open it so wide that your brains fall out.
thundercatken is offline   Reply With Quote
Old 11-23-2008, 04:55 PM   #3 (permalink)
Mother's Avatar
Thaks ken thats my concern NIMBY(not in my back yard) I like to sneak in and out of my own 'hood
TwinTec ignition
Rivera Pro-Clutch
Thunderheader
3.37's
Pirelli tires
Old 11-23-2008, 05:17 PM   #4 (permalink)
04GLIDE's Avatar
04GLIDE is on a distinguished road
I have an LSR and a buddy has a thunderheader. My LSR is much quieter at idle and at low RPM. I can sit next to a LEO at a stop light and he won't even look at me. I leave my house everyday at 6am and my neighbors say they don't hear me. When I twist the throttle it's a whole different story. It gets as loud as the thunderheader does. I like it as it's stealthy when you need it to be.
04 GLIDE
95" 10.5 -1 S&S
TC-2G cams
RB Racing LSR 2 into 1
Ness Big Sucker
04GLIDE is offline   Reply With Quote
Old 11-23-2008, 06:18 PM   #5 (permalink)
Just out of curiosity ... Do you also have the "Turn Down"? I know of one other LSR in the area, and his pipe exits straight back ... seems a bit louder. It might be my imagination, but with the exhaust pointed down ... it seems to make a big difference at low RPM. Wide open is another story
Ken M
2003 FXDWG
Old 11-23-2008, 08:21 PM   #6 (permalink)
Buddha4's Avatar
Buddha4 is on a distinguished road
I went from the thunder to a LSR slash cut on my 95 the LSR is a "deeper' sound. Going with the unscientific meathod of asking the neighbors they prefer the sound of the RB's at 0500. They prefer the "tone" of that over the Thunder which makes me think the sound is not as annoying regardless of db level.
One of the neighbers had a Fatboy with straights which was just loud
IBA 31086
Buddha4 is offline   Reply With Quote
Old 11-23-2008, 11:41 PM   #7 (permalink)
et > trap speed!
skyhook is on a distinguished road
rbracing is one top-notch outfit...lsr is a LOUD pipe...if ya want quiet supermeg rules....unless motor has potential to make 115 or more...then d&d boarzilla is king
08 fxdse 110", r&r heads, 257 cam, hp inc 55mm, supermeg
07 fxdb 96", al taylor "blueprint plus" heads, 37 cam, fatcat
05 flhr 103", SEp heads(cleaned up), 10.7 comp, 251 cam, roadrage
88 xl1200, dale miller heads, 12.5 comp, se cams, kerker exh, 40mm carb
if I wanted to ride a couch, I'd just stay home!
skyhook is offline   Reply With Quote
Old 11-24-2008, 01:11 AM   #8 (permalink)
04GLIDE's Avatar
Yes I have the 45*turn down.
04 GLIDE
95" 10.5 -1 S&S
TC-2G cams
Ness Big Sucker
Old 11-24-2008, 10:56 AM   #9 (permalink)
Just another Hog Jocky
mtnmotorrider's Avatar
mtnmotorrider is an unknown quantity at this point
I had both the TH and the RB LSR 2-1 on the same Softail. The TH exited out the back, the RB had a 45 degree kick out to the side. I got rid of the TH because I couldn't tolerate the noise level, even with a helmet on. The RB never bothered me, even on 10 to 12 hour days. If I was going to ride for that long and not have a 3/4 helmet on, I would use ear plugs. Those were mainly for the wind noise, though. I'm planning on another RB LSR for my bagger now.
My friends like me; everyone else thinks I'm an asshole. What's that say about my friends?
'07 Road Glide, 103 ci, Big Boyz "Bigger Valve" Street Port 85 cc heads, .030 quench for 10.2:1 cr, SE flat tops, Wood TW 6-6's, K&N air filter, Rush slip-ons, TMAT
mtnmotorrider is offline   Reply With Quote
Old 11-28-2008, 08:09 AM   #10 (permalink)
Mother's Avatar
What was the difference in power? noticable?
TwinTec ignition
Rivera Pro-Clutch
Thunderheader
3.37's
Pirelli tires
Old 12-01-2008, 05:08 PM   #11 (permalink)
I had different cams in between, so can't compare. The RB did pull the flatest torque curve, though.
