During the heating/cooling cycle, the shields will slip down a bit. You can (temporarily) get rid of the noise by loosening all the clamps on each shield, and pushing them up towards the heads. Then retighten the clamps. Slide the clamps up as close to the heads as possible too before tightening. The noise will go away, until the slip down in a few weeks again. AustinFXDWG
AustinFXDWG
2005 FLTRi Road Glide - 95", SE Flat-tops, SE-AC, SEPro Slipons, Bassani Power Curve True Duals, Dynojet PCIII, HD Oil cooler, Mustang Touring Solo saddle, Fog Lamps, and HogTunes Speaker. Now we';re cruisin'...
