Vance and Hines Fuelpak question : V-Twin Forum: Harley Davidson Forums
Old 12-24-2012, 08:36 AM   #1 (permalink)
Headache wants to know Dino or Syn?
I have a 2009 Fatboy and just recently purchased a V&H Fuelpak and a set of Big Radius 2-2 pipes. I picked them up yesterday and when I got home I was reading the box on the fuelpak. It was then I noticed it said it was for softails with 140mm tire. I looked on the website and it indicates there is a separate part number for the one with a 200mm tire, like the fatboy. The part number I received was 61001A. The one for my bike is 61007A. I tried calling V&H but they are closed for the holidays. I haven't broken the seal or opened the box yet.
My question is why do they have different models for the regular softail and the fatboy?
I now have to wait until at least Wednesday to fix this problem. This is the second "wrong" part that I have received in the last week (2 different shops). I'm beyond aggravated.
John
Headache is offline   Reply With Quote Quick reply to this message
Old 01-01-2013, 08:51 AM   #2 (permalink)
cata5803's Avatar
cata5803 wants to know Dino or Syn?
John
Good question why there's a difference, my guess would be the mounting of the unit...
2008 FLHTI Standard (29 of 200)
cata5803 is offline   Reply With Quote Quick reply to this message
Old 01-01-2013, 11:25 AM   #3 (permalink)
werdna65 wants to know Dino or Syn?
I have bought used fuelpaks and only thing different was the length of the wire from the tuner to the plug. There also is a different style plug for the newer touring, maybe other models I think 2009 models is the year they changed them. The bracket/ tray can be bought sepreatly from V&H, softails also use a deeper tray for all the things to stack up on. Hope this helps
werdna65 is offline   Reply With Quote Quick reply to this message
Old 01-09-2013, 10:27 PM   #4 (permalink)
Thanks guys. I returned it for the proper model. I was afraid that if I opened it and it didn't work, they wouldn't take it back. I just finished mounting the proper one. They have it engineered to just fit under the seat. There was absolutely no room to spare.
John
Old 02-08-2013, 07:22 PM   #5 (permalink)
leeanders's Avatar
leeanders wants to know Dino or Syn?
V&H Fuel Pac #61007A (Fatboy)
John
John,
I'm thinking of buying one for my 2013 Fatboy.....tell me what you think of yours, now that you've had it on your bike for awhile.
Thanks.
#15: 2013 Softail Fatboy
leeanders is offline   Reply With Quote Quick reply to this message
Old 02-12-2013, 09:13 PM   #6 (permalink)
Lee,
I have only ridden it a couple of times and I still had the stock air cleaner on it. I seemed like it was running a little rich. There were a couple of pops occasionally when backing off. Nothing significant though. Overall, I really like it, so far. There is definitely a difference in power. The throttle response seems to be a little better also.
As far as the install, the pipes were easy and straight forward. The toughest part was removing the old pipes. I removed them a piece at a time and was wrapping them as I went, so they wouldn't get scratched. I followed the instructions to the letter for the installation of the new pipes and everything went without a hitch.
The install of the Fuelpak was also pretty simple. I did have to remove the ECM from the fender in order unhook the existing plug and install the new one. I tried to be creative on placement and fought it for a couple of evenings. The seat would not go back in place. I finally accepted my failure and used the diagram supplied by V&H. I was finally able to get it to fit, but there is zero extra space. I did have to relocate a small rectangular module from the front of the battery to an area a little forward of it's previous location.
I have now put on a Screaming Eagle heavy breather, but have not yet started it yet, so I can't rate final performance.
John
