cleaning burned plastic or what ever on pipes : V-Twin Forum: Harley Davidson Forums
Old 12-04-2012, 07:49 PM   #1 (permalink)
swordfish wants to know Dino or Syn?
after a while my pipes are looking pretty ratty from burned on boot or oil or what ever. I've try everything from pig spit to chrome polish
easy off works ok but is not good for the chrome.. so i'm about throw in the towel , then i see the wife cleaning our new glass cooktop with a product called weiman cooktop cleaner so i try it on my pipes wow! 10 minutes look like brand new pipes it uses a soft red scrub pad and does not scratch the chrome. this really works
swordfish is offline   Reply With Quote Quick reply to this message
Old 12-04-2012, 10:20 PM   #2 (permalink)
spdrcr137's Avatar
spdrcr137 wants to know Dino or Syn?
brake cleaner
spdrcr137 is offline   Reply With Quote Quick reply to this message
Old 12-04-2012, 11:15 PM   #3 (permalink)
Rendell's Avatar
Rendell wants to know Dino or Syn?
easyoff oven cleaner read the directions and adapt to make them work.
06 FLHTCUI Ultra Classic
Rendell is offline   Reply With Quote Quick reply to this message
Old 12-05-2012, 02:37 PM   #4 (permalink)
hmmm..tough audience..
Old 12-16-2012, 01:07 PM   #5 (permalink)
95BadBoy's Avatar
95BadBoy wants to know Dino or Syn?
Cleaner
I use WD-40 to get rid of boot scoffs.
1995 Bad Boy, Engine built to HD Stage 4 in 1998
Branch #5 heads, Matching Branch 11.5 Pistons
SE big bore intake manf W/42mm Mikuni
SE-57 cam, Crane 3/8 molly adj push rods
32" x 2.25 OD exh pipes Hyper charger air cleaner
Dyna 2000i adj ignition sys.
Blue streak Hi Opt coil W/10mm wires.
Dynoed at 93.5 HP
95BadBoy is offline   Reply With Quote Quick reply to this message
Old 12-16-2012, 02:03 PM   #6 (permalink)
thefour's Avatar
thefour wants to know Dino or Syn?
I use a razor blade and wd40. Just be real careful.
thefour is offline   Reply With Quote Quick reply to this message
Old 12-16-2012, 02:06 PM   #7 (permalink)
hogcowboy's Avatar
hogcowboy wants to know Dino or Syn?
I had a spot of black crud of some kind and scraped it off with a penny. Then shined every thing up with kitchen wax. Looks great now.
Do everything like your life depends on it. It could!.
hogcowboy is offline   Reply With Quote Quick reply to this message
Old 12-16-2012, 04:38 PM   #8 (permalink)
tweaked1973's Avatar
tweaked1973 wants to know Dino or Syn?
EZ off is great. It works on burned on oil too. Just don't get it on the paint.
tweaked1973 is offline   Reply With Quote Quick reply to this message
Old 12-16-2012, 04:43 PM   #9 (permalink)
I haven't seen your bird.
MadCity's Avatar
MadCity is reading this now saying WTF is this?
I had some burned-on oil on my rocker boxes once, and I was having trouble getting anything to touch it. My wife suggested nail polish remover. It took the oil right off without marring the chrome.
03 XL1200 Custom
MadCity is offline   Reply With Quote Quick reply to this message
Old 12-16-2012, 04:54 PM   #10 (permalink)
Rollmeaway's Avatar
Rollmeaway wants to know Dino or Syn?
Ya gotta love those ladies with painted nails ...
If ya can get at it while it is fresh use a fire extinguisher it'll pop right off. Had a Bunny touch down on the pipes with a high heeled boot about the size of a dime ... got lucky that day ... cause it wasn't 10 minutes old.
We never even said a word,
And we rolled...
Dare...
2000 FXST - Carbed
Rollmeaway is offline   Reply With Quote Quick reply to this message
Old 12-16-2012, 06:00 PM   #11 (permalink)
HDSickness wants to know Dino or Syn?
When pipes are cool scrape off with a penny........Works great ......seriously.
HDSickness is offline   Reply With Quote Quick reply to this message
Old 12-16-2012, 06:32 PM   #12 (permalink)
guydoc77's Avatar
guydoc77 wants to know Dino or Syn?
I get the pipes hot until the stuff on them melts.
Then I wipe with a towel being careful to make quick wipes and turn the towel to it's opposite side each wipe. The goal is to get all the stuff off except a very fine film.
Then let the pipes cool.
After cooled, take fine steel wool and gently remove the residue.
Works for me. And fine steel wool doesn't scratch the chrome of the shields.
2008 Road Glide
Phoenix Customs Bagger Brace
Glide Pro
Clearview windshield
107
CP flat tops
R&R Stage 3 heads, .030 gasket, 82cc chambers
Trued, welded, and balanced crank by Hyperformance
TMan 590 cams
SE AC
HPI 54mm TB
Supermeg with open cap and 15 discs
TTS tune by BVBob
2003 Indian Scout Deluxe
Aspen White (got it for my wife)
S&S "SuperStock" 88"
12" apes
Scary fast!
guydoc77 is offline   Reply With Quote Quick reply to this message
Old 12-16-2012, 07:22 PM   #13 (permalink)
sporty952 wants to know Dino or Syn?
Synthetic towels are really soft...
sporty952 is offline   Reply With Quote Quick reply to this message
Old 12-17-2012, 08:57 AM   #14 (permalink)
J Rayburn wants to know Dino or Syn?
cleaning chrome on your Harley
Try steel wool; it also works.
J Rayburn is offline   Reply With Quote Quick reply to this message
