10-27-2012, 06:06 PM
Lifter Sound
2012 EG Limited 5000 miles, went up to Daytona for Bike Week, while I was there Rush installed a modified rear hanger on my front pipe, he loosened the flange nuts and installed the new hanger. Now since then I am hearing this tinning noise like lifters, changed my oil, and its still there, I pulled the plugs, they are normal. I don't think its related to the exhaust work, but I can't seem to figure it out, any suggestions? Thanks
Sent from my SCH-I535 using Motorcycle.com App
10-27-2012, 07:05 PM
Could be an exhaust leak
10-27-2012, 07:17 PM
I would check the heat shields screws for tightness and that they are not hitting frame parts when the engine is running
Regards,
John
2002 Road King Classic w. 103" Stroker
2007 VRSCX 0461 / 1400
2003 VRSCA (Gone but not forgotten)
10-27-2012, 08:09 PM
I would first suspect it's related to the last work done. I would change the exhaust gaskets.
"Our lives begin to end the day we become silent about things that matter"
10-28-2012, 12:34 AM
10-28-2012, 03:14 AM
Will do that today, will check the shields also. Thanks for the info everyone.
10-28-2012, 07:26 PM
Well took the front pipe off at 4:30 this morning, pulled the old gasket out, it looked fine, cleaned off the studs with wire brush, installed new stock gasket. Noise still there, stop at the HD dealership, they said 5000 miles, give it more miles, then we can check it. They said that it is normal, I didn't hear it before. Well I'll wait until 7500 miles,and see if it goes away. Thanks to everyone, maybe I should pull the rear pipe, and check that.
10-29-2012, 06:55 PM
What is this modified rear hanger? Why was it necessary and what does it do? Maybe a picture of it is in order.
Regards,
John
10-29-2012, 07:19 PM
My guess is the heat shield is rubbing on the cylinder head. You might check that.
11-04-2012, 09:27 AM
Yes the 2012 EG the rear hanger that came with Rush True Duels are to long, they have a shorter one. They fixed mine at Daytona by adding the short hanger. Now everything looks great, and there is clearance between the rear brake clevis and front pipe.
11-04-2012, 10:16 AM
Is it possible that it developed a small crack in a weld joint ?
I would call Rush and explain the circumstances to them , while it's still recent.
Sounds like it started doing it right after they made the hanger change, usually that's not just coincidence.
| Sponsored Links |
