which 2 into 1? supertrapp supermeg or D&D boarzilla/bosszilla? : V-Twin Forum: Harley Davidson Forums
Old 06-18-2011, 01:15 PM   #1 (permalink)
keeven wants to know Dino or Syn?
looking for the most hp and torque through all ranges. i have a 2011 streetglide with a 120 ci harley motor with 12.1 comp pistons, cnc/mva heads, 264 cams, 58mm tb. running a v and h x pipe 2into1into2 right now and dyno reads 124hp/100tq at rear wheel. i believe it can do better.
keeven is offline   Reply With Quote Quick reply to this message
Old 06-18-2011, 09:49 PM   #2 (permalink)
shovel13 wants to know Dino or Syn?
So many choices and a good start would be RB Racing. The company has a lot of info on their site.
shovel13 is offline   Reply With Quote Quick reply to this message
Old 06-18-2011, 10:41 PM   #3 (permalink)
HATER OF THE GRAVEL!!!!!!
Jeffytune's Avatar
Jeffytune is reading this now saying WTF is this?
The Vance and Hines High output pro pipe.
http://www.vanceandhines.com/product...t21chrome.html
I'm Just Sayin'...
2010 FLHTCUI
96 CID w/ the quiet 6 speed
K&N RK-3930 air filter
Harley quiet high flow 110 mufflers
Vance and Hines Fuelpak
Professional Rockat Surgen
Disclaimer.
Jeffytune is offline   Reply With Quote Quick reply to this message
Old 06-19-2011, 08:44 AM   #4 (permalink)
smitty901's Avatar
smitty901 is reading this now saying WTF is this?
Look at the HD night stick lower cost than super trap and works just as well
Infantry leads the way
smitty901 is offline   Reply With Quote Quick reply to this message
Old 06-19-2011, 09:30 AM   #5 (permalink)
strokerjlk's Avatar
you need to get that thing breathing. Bosszilla will work great on that 120.
look at wegner x or wegner 2-1 also.(uses mufflers made by s/t built to wegner spec)
that said ....that v&h x should do better than what you have now.
I tuned the v&h x on a stage 1 cvo 110 bike. it made 115 ish TQ.
how did you get your compression to 12:1 with the MVA heads?
hurricane pistons?
07 ULTRA
AMRA
SE 218
DR 218
Old 06-19-2011, 11:49 AM   #6 (permalink)
Unca Mike wants to know Dino or Syn?
The main advantage to the Supertrapps is that they can easily be tuned by adding or subtracting discs. Less back pressure will give more power on top and more back pressure will help in the low and mid range (at some sacrifice to top end power). Personally I like the quality of V&H stuff but if I were in the market for a go fast package I'd go for the Supertrapp just cuz of its easy tune-ability. I've also read that with the V&H Pro Pipe you can also get a standard or "competition" (meaning loud and free flowing) baffle.
I have a good friend that has a custom shop in San Jose and he said it's much easier to get more than 1 hp/c.i. with an Evo than with the Twin Cams. Not sure why. I'd be curious to hear what other engine builders have to say about this. I know most of the big aftermarket engines are Evo designs and not Twin Cam.
Unca Mike is offline   Reply With Quote Quick reply to this message
Old 06-20-2011, 12:57 PM   #7 (permalink)
I have a v and h x pipe with hi output slip ons on it right now.
Old 06-20-2011, 02:23 PM   #8 (permalink)
blue flht wants to know Dino or Syn?
hurricane pistons?
Do you have a pic of the wegner 2-1, or a wedsite to go too?
2010 FLHTK T-MAN 107 STAGE 2 HEADS 600 SM CAM EVO 49T FATCAT BOSS
blue flht is offline   Reply With Quote Quick reply to this message
Old 06-20-2011, 02:42 PM   #9 (permalink)
Inspector 12's Avatar
Inspector 12 wants to know Dino or Syn?
I have the Vance and Hines Pro pipe hi output 2-1 on my SE 120R and it works very well. Don't have near the compression you do and getting 139.92 hp and 133.7 tq
2010 FLHX, Stage II 103,255 cams
D&D Fatcat, SEPST, Factory 68 hp 84 tq, Now 92 hp 106 tq
06 Street Bob, SE 120R, VH Propipe HO, SERT, 139.92 hp, 133.70 tq.
Inspector 12 is offline   Reply With Quote Quick reply to this message
Old 07-14-2011, 08:57 AM   #10 (permalink)
se120rx wants to know Dino or Syn?
I am a true believer in the wegner 2 into 1. You sould try it! I've ran and it very nice. I'm running 120rx 12:1, hurricane heads, rx267 cams, roller rockers, 64mm tb, with the 2 into 1 at first and then the x from wegner. The flhxse2 has the cut outs for the pipes, that why I am now running the x with duals.
se120rx is offline   Reply With Quote Quick reply to this message
Old 09-10-2011, 12:47 PM   #11 (permalink)
Warrior Seal's Avatar
Warrior Seal wants to know Dino or Syn?
Where do you guys suggest we should get the Wegner pipes?
Warrior Seal is offline   Reply With Quote Quick reply to this message
Old 09-14-2011, 07:30 AM   #12 (permalink)
monkeybutt's Avatar
monkeybutt wants to know Dino or Syn?
Just to muddy the waters a little I'll throw in my vote for the boarzilla. If you don't mind a little loud (mine has standard baffle), my 117 made 138hp/131tq with this pipe. These numbers may change somewhat as I'm going to see Ed at The Dyno Difference in a couple weeks for a more thorough tune.
2012 FLTRX
Drago's 124 crate motor (fun)
monkeybutt is offline   Reply With Quote Quick reply to this message
Old 09-14-2011, 07:55 AM   #13 (permalink)
troop wants to know Dino or Syn?
Just googled Wegner exhaust and damned near choked on my coffee. They don't give their stuff away do they !!!
103" flat tops with .030 hg
Tom Wirth Street Port Heads
Andrews 54H Cams/1.725 rocker arms
K&N Aircharger/SEPST
V&H Pro Pipe
JVC/BT4180 Amp/Focal/Kicker/HT Lids
troop is offline   Reply With Quote Quick reply to this message
Old 09-22-2011, 02:40 PM   #14 (permalink)
FatBob120R wants to know Dino or Syn?
I run the Boarzilla 2 into 1s on my 120R and have no complaints. Those were the pipes that the dealer who installed my motor recommended and that's why I went with them. My bike dyno'd at 130 hp and 124 torque.
FatBob120R is offline   Reply With Quote Quick reply to this message
Old 09-23-2011, 08:19 AM   #15 (permalink)
JTW
JTW wants to know Dino or Syn?
I am completely biased here, but I did just spend the last weekend in the rocky mountains for a distributor event riding a streetglide with a Jims 131, with our Supermeg on it. Works extremely well and is quiet. Jim, of Jims Machine was there with one of his new 135's with the bosszilla pipe, and it works well also, but is extremely loud. It makes good peak, but doesn't seem to have the bottom end torque that ours had.
It depends on how the motor is set up and what you want out of it.
We also make the mufflers for the Wegner stuff, and they are pretty quiet also.
JTW is offline   Reply With Quote Quick reply to this message
