poor man's true duals? Stock crossover bypass? : V-Twin Forum: Harley Davidson Forums
Old 06-02-2011, 02:26 AM   #1 (permalink)
JustDave71's Avatar
JustDave71 wants to know where he is and how he got here
Found this setup that eliminates the factory crossover apparently by plugging the crossover holes...guy's selling it for not many bucks...made by Big Daddy's or something like that?
Can't find any info at all online. Anyone seen or used these before?
see attached.
JustDave71 is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 09:43 AM   #2 (permalink)
TIMTOOLMAN wants to know Dino or Syn?
I have, also back 10 or so years ago it was a common thing to use automotive freeze plugs to plug up the left side exhaust except for a small hole in the middle to make a 2-1. Same to make cheap dual system. zippers did that quite a bit. Its just auto- freeze plugs and a harley exhaust clamp. It had better be realllllly cheap
2009 ultra
hillside 117
S&S Crank/ Timkin
hillside stage 5 2nd gen heads
woods 400-6 cams
woods directional lifters
H.P.I. 58/58 T.B. with 1.800 intake runners.
6.2 injectors
s&s p rods
woods billet rocker supports, .030 offset
Rush Wrath 2-1
S.E.cam plate S.E. H.V. oil pump
Axtell oil bypass mod
tts Tuner
doherty p/p intake modified for hillside big green air filter
S.E. compensator
30 tooth pulley
big sky dual oil cooler fans
HTCS AW/SW USN RET
TIMTOOLMAN is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 09:49 AM   #3 (permalink)
Basic Hog Rider
xxxxxkwizard wants to know Dino or Syn?
Dude, don't waste your money. If I remember there is a step by step post here that shows how to do the freeze plug mod.
xxxxxkwizard is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 09:50 AM   #4 (permalink)
JustDave71's Avatar
LMFAO is that all it is basically? ha!
$35 plus shipping he wants, but...seemed like a lot for two plugs and a clamp, plus...hell...why go to all the hassle to eliminate the stock crossover? Probably lose a little oomph if I did that anyway!
Old 06-02-2011, 09:51 AM   #5 (permalink)
JustDave71's Avatar
FUnny how you both posted at once
see if you can find that post? I'll look, too. Curious.
Old 06-02-2011, 10:45 AM   #6 (permalink)
Basic Hog Rider
Here it is JD71.
http://www.hdforums.com/forum/tourin...s-at-home.html
Old 06-02-2011, 10:47 AM   #7 (permalink)
JustDave71's Avatar
This site rocks. At the very least I'll learn somethin.
Would eliminating the OEM crossover change the sound? Temp dispersion? I'd assume it'd affect torque a little but probably not very noticeable?
Old 06-04-2011, 05:47 AM   #8 (permalink)
JustDave71's Avatar
so yeah that's pretty damn funny to pay anything more than a few bucks for this DIY. Cracks me up how often people try to sell very common parts for much more than they'd normally go for just because they're "for a harley." I see that with fasteners a lot. Someone picks up a bunch of fasteners from a hardware store and labels them "for harley" and suddenly they're worth 5X?
bah.
anyway...just remembered I have a friend who works at a muffler shop. If i really wanted to convert my stock exhaust to true dual, couldn't I just have him cut the crossover out and weld in fillers?
Old 06-04-2011, 07:18 AM   #9 (permalink)
Basic Hog Rider
Just have him weld the freeze plugs. When you re install the heat shield it's going to hide everything. The torque loss you hear everyone ranting about is hardly noticable. What is very noticable is the stereo sound from the individual cylinders firing, and the exta snap you will feel in high speed roll ons.
Old 06-04-2011, 07:43 AM   #10 (permalink)
JustDave71's Avatar
10-4 on the freeze plugs, but if I understand it, that leaves sections of crossover hanging. The heat shield is then re-attached to cover the gap? I'd rather not have those hanging sections and would also rather leave the heat shield off there as well, for a cleaner open look
just being anal, but...no reason not to do it that way, right?
as for torque...this bike isn't anything resembling a torquer so...no big. I'd like the extra crackle and top end.
