Supertrapp: 2-1 Supermeg vs 2:2 Fatshots : V-Twin Forum: Harley Davidson Forums
Old 12-18-2010, 03:10 PM   #1 (permalink)
Are you kidding me?
Friedenfels wants to know Dino or Syn?
Thinking about one of these, especially most recent dyno shows I am leaving a lot of horsepower on the table with the V&H Double Barrels: only 76 horsepower and 96 ft lbs.
Anyway, the fatshots maintain the 2:2 shotgun look, but is there a difference in performance between the two? Even using the disc technology, will the 2:1 still be the better performer? The 2-1 pipe is about $160 cheaper...$600 to $760 for the fatshots.
Merry Xmas to all.
2009 FLSTF
S&S Air Cleaner
SEST
SE-204s
V&H Double Barrels
Friedenfels is offline   Reply With Quote Quick reply to this message
Old 12-18-2010, 03:28 PM   #2 (permalink)
guydoc77's Avatar
guydoc77 wants to know Dino or Syn?
Could only guess at exact numbers. Generally speaking though, you gain area under the torque curve, especially on it's left side, with a good 2:1 pipe. This makes for a stronger low end, generally in the 2000-3000 RPM range. You do lose a little hp in the upper RPM range though with a 2:1. Again this is a broad generalization. To me, the 2:1 is the choice for anyone who is riding a stock or mildly built street bike, especially a bagger, precisely due to the definite increase in low end torque.
2008 Road Glide
Phoenix Customs Bagger Brace
Glide Pro
Clearview windshield
107
CP flat tops
R&R Stage 3 heads, .030 gasket, 82cc chambers
Trued, welded, and balanced crank by Hyperformance
TMan 590 cams
SE AC
HPI 54mm TB
Supermeg with open cap and 15 discs
TTS tune by BVBob
2003 Indian Scout Deluxe
Aspen White (got it for my wife)
S&S "SuperStock" 88"
12" apes
Scary fast!
guydoc77 is offline   Reply With Quote Quick reply to this message
Old 12-20-2010, 07:51 AM   #3 (permalink)
JTW
JTW wants to know Dino or Syn?
The 2:2 FatShots with the large diameter head pipes will give you more in upper mid-top, the 2:1 will be a better bottom-mid.
Exactly as Guy said, your bike/build the 2:1 is probably the better choice.
JTW is offline   Reply With Quote Quick reply to this message
Old 12-21-2010, 04:03 AM   #4 (permalink)
Are you kidding me?
JTW - I assume the 2:1 is a better choice due to the scavenging effect by both pipes.
Yet, with the discs, cannot the fatshots be adjusted to enhance the bottom end?
Just trying to understand all this.
TIA
Oz
2009 FLSTF
S&S Air Cleaner
SEST
SE-204s
V&H Double Barrels
Old 12-21-2010, 07:52 AM   #5 (permalink)
Yankee Ride's Avatar
Yankee Ride wants to know Dino or Syn?
TIA
Oz
Tim- that makes two of us!! Thanks for asking some good questions. I'm learning too! YR
CLS (Certified Lubrication Specialist)
STLE (Society of Tribology & Lubrication Engineers)
2015 Indian Scout
09' FLHCTU
PC-V
Wild Pigs slip on's
Kuryakyn Sleeper II intake
K&P Engineering Oil Filter
78 HP
91.6 Ft. Lb.
84' RZ 350KRL (street legal metric 2 stroke)
highly modified
Yankee Ride is offline   Reply With Quote Quick reply to this message
Old 12-21-2010, 12:31 PM   #6 (permalink)
JTW
Correct, and the smaller diameter primary for better torque on the stock or mild motor.
To a point yes, but the 2" diameter pipe is really the issue with the low end torque. They are great up top.
TIA
Oz
Old 12-21-2010, 04:38 PM   #7 (permalink)
Are you kidding me?
Ok, to take this a step further: Suppose a guy takes his stock to mild motor and moves up to a 103/106/107 (10:1-ish compression), some headwork, and maybe keeping the 204 cams or maybe an Andrews 54. Does the equation change at all, or is this still considered a mild motor and the 2:1 still the champ.
As you may have guessed, kinda leaning towards the fatshots because it keeps the 2:2 pipes.....not against a 2:1, but, well, you know. BUT....dont want to leave any "free" power on the table, especially given the 2:1 is cheaper.
2009 FLSTF
S&S Air Cleaner
SEST
SE-204s
V&H Double Barrels
Old 12-27-2010, 05:56 PM   #8 (permalink)
GAZRNR's Avatar
GAZRNR wants to know Dino or Syn?
I have used both Rush slip on mufflers and a Supertrapp supermeg 2:1 exhaust on my Road King. The slip ons have a louder idle & louder cruise sound but the extra heat in my crotch got me to try the 2:1 Supertrapp. Ran the Supertrapp with 9 discs and open end cap and with 18 discs and closed end cap. The bike ran best with the closed end cap & 18 discs. It is not to loud when I am cruising and barks when I let it rip. I am going with the SuperTrapp Supermeg 2:1 on my 09 RG. The 09 currently has Woods TW6-6 cams, Rinehart mufflers, PCV & autotune with a 107 kit in the works. IMHO The ST 2:1 is the way to go and it can grow with my build. If you still arn't sure which way to go call Jamie at Fuelmoto, tell him what you have and what you want and he will shoot you straight.
GAZRNR is offline   Reply With Quote Quick reply to this message
Old 12-28-2010, 09:41 AM   #9 (permalink)
fatshots have no business on any motor. even if you had the cubic inch (over 117) , the cams (over 650 lift), and heads (over 3000) to make power in the area those pipes would begin to TRY to work, there are much better exhausts for the application.
bottom line? they are too big and tuned for no particular application.
Old 12-28-2010, 01:41 PM   #10 (permalink)
JTW
Yes, intended for bigger motor, but they work very well, maybe try them next time you're on the dyno?
Old 12-29-2010, 07:59 AM   #11 (permalink)
no need for next time. clamping straps across the outlets will show a torque gain and more area under the curve. been there.
