True Duels : V-Twin Forum: Harley Davidson Forums
Old 07-30-2010, 07:28 PM   #1 (permalink)
b dukes wants to know Dino or Syn?
True Duels
I have a 2002 Ultra. I have been thinking of buying a true duel header set. Are there any advantages of purchasing this or any problems they could cause.
b dukes is offline   Reply With Quote Quick reply to this message
Old 07-30-2010, 08:46 PM   #2 (permalink)
Swamprat Rider
JayFL459's Avatar
JayFL459 wants to know Dino or Syn?
I love True Duals Myself The Sound and Looks are unbeatable .. You may sacrifice a tad of power but not enough to worry about ..
2012 Vic Cross Country Stage 2/ 2015 Indian Scout Stage 1
JayFL459 is offline   Reply With Quote Quick reply to this message
Old 07-30-2010, 09:14 PM   #3 (permalink)
shedman's Avatar
shedman wants to know Dino or Syn?
Are you asking what is the difference between your stock exhaust (presumably dual crossover in an ultra) and an aftermarket non-crossover dual (true dual) exhaust?
A crossover improves exhaust flow and torque at low and mid rpms.
However aftermarket dual pipes will flow better, so overall you might lose some low end torque but gain high-rpm horsepower. Backpressure can be improved by using quiet baffles or extra baffling which will improve the low end torque.
2010 Softail Deluxe - GMR 117 build:
Axtell 117 kit, -10 CC pistons, Andrews 54 cam, CNC Heads, HPI 51mm TB, Hobans crank, Rivera Primo Clutch, Bassani Hutch special dual headpipes, Supertrapp universal IDS mufflers. Compufire III Gen III starter motor.
shedman is offline   Reply With Quote Quick reply to this message
Old 07-30-2010, 09:14 PM   #4 (permalink)
shedman's Avatar
Good article about different exhaust types:
http://www.harley-performance.com/harley-exhaust.html
Another concentrating on crossover pipes:
http://www.americanrider.com/output.cfm?id=1021987
Old 07-30-2010, 10:04 PM   #5 (permalink)
your cams and heads have quit by the time the duals start to work.
Old 07-31-2010, 01:06 AM   #6 (permalink)
Zwiehund's Avatar
Zwiehund wants to know Dino or Syn?
claydbal speaks the truth. With stock or lightly modified motors, it is a looks and sound thing. And I got a little bit more vibration due to unequal length pipes giving me 2 different tq curves and AFR lines. But I sure like the sound. And they are expensive too, unless you go with something like Fulsac, which works nicely.
2004 FLHTCI with Khromewerks Mufflers, Fullsac headers, Stage I Download, Dobeck TFI, Big Sucker, Saddlemen Gel Seat, Windvest Windshield, Cruise, HD Stainless Pullbacks, Throttle-Up Touring Stabilizer, Andrews 21N Cams, Herko Hydraulic Tensioner Upgrade Kit, Hogtunes Sound.
A perfection of means, and confusion of aims, seems to be our main problem.
Albert Einstein
Zwiehund is offline   Reply With Quote Quick reply to this message
Old 08-07-2010, 06:35 PM   #7 (permalink)
cata5803's Avatar
cata5803 wants to know Dino or Syn?
I put Rush True Duals on my Limited and had the Oval slip ons. I really like the Duals, I had it Tuned (TTS) by Doc shortly after instlation. He claimed that set up on my bike was the easiest tune he's experianced..
2008 FLHTI Standard (29 of 200)
cata5803 is offline   Reply With Quote Quick reply to this message
