Custom DynamicsCycleGear.comSportbikeTrackGear
Pro PadAdvanstarMotorcycleShowsFuel MotoAmerican Side Road CycleJardineProducts.comMotorcycle.com Classifieds!
Old 10-22-2009, 05:52 PM   #1 (permalink)
BadWeather is on a distinguished road
RB Racing LSR Pipes
Does anyone know the differences in torque and noise between the standard 2:1 LSR and the 2:1 Pro Stock. I am not interested in the Spyder or Black Hole versions as I'm sure these will be to quiet. I'm currently running a D&D Fatcat and OK with the noise. I'm concerned that these LSR pipes will hurt low end torque and are more designed for WOT riding then the cruising that I do. Thanks in advance.
06 CVO 113 Ultra
SE MVA Heads
SE 251
SE 50mm TB
SE 10.5:1
ThunderMax ECM
Zipper A/C
AIM 92T VPC
D&D Fat CAt
3.37 Final Gearing
BadWeather is offline   Reply With Quote
Old 10-22-2009, 06:03 PM   #2 (permalink)
midnight sporty's Avatar
midnight sporty is on a distinguished road
id be interested in this also
08 crossbones
hillside 107
woods tw8 cams
hillside stage 3 heads
s&s roller rockers
s&s adj pushrods
55 hpi throttle body
larger injectors
D&D fatcat-perf baffle
vp92t
hillside air filter
230 ccp
not one ounce of pinging
hillside cycle...
midnight sporty is offline   Reply With Quote
Old 10-22-2009, 08:23 PM   #3 (permalink)
Formerly 04GLIDE
03GLIDE_'s Avatar
I don't have numbers for you but I ran a LSR on my bagger for about four years. It wasn't too loud but I am deaf. Bottom end was still good with it. I would still be running it if I hadn't totaled the bike.
Old 10-22-2009, 08:30 PM   #4 (permalink)
Search this section of the forum for posts by "Nowhereman". He has a solution. I don't remember
the name of the company but they have a cone or baffle you can install in the RSB Pro Street.
Better torque, better sound.
_______________
04 softail standard
Baisley-Axtell 117 - Baisley pro street heads - Baisley hybrid injection
Bob Wood TW-8 - Darkhorse crank - P.M. Hydraulic clutch
P.M. Villain wheels-rotors
Builder - hdryder
Phat117 is offline   Reply With Quote
Old 10-22-2009, 08:52 PM   #5 (permalink)
ULTRA LIMITED ON THE WAY
laserp's Avatar
laserp is on a distinguished road
I have the baffled LSR, turned out, 45 down and highly recommend it. Sounds great, well balanced, no dip what so ever off the line, runs well right up to the rev limiter. Blows away my old Rhinehart 2-2. Form, fit and function are right there. The key is to match the primary size with your engine. I went with the 1.75's and they are right for my 103, probably right for your bike too.The 2 inch primaries don't come into the picture until your pushing 110/117 CI, if you get greedy and go too big with the primaries, then you probably will have a low end dip problem.
The prostock is really cool, with the quite riot baffle install. Dwood has that setup and loves it. Either way you will be good.
Some here complain about R&B CS... I had no problems. Ordered my pipe in Dec. and received it in 3 weeks as promised and never looked back.
02 FLSTCI, 103, HTCC Ported Heads, 10.6:1 static comp, SE 251 cam, SERT, TSII+, RB 1 3/4 C LSR 2-1 Pipe
laserp is online now   Reply With Quote
Old 10-22-2009, 09:50 PM   #6 (permalink)
DURWOOD's Avatar
DURWOOD is on a distinguished road
I really like mine,a huge improvement over the V & H 2-2s I had,Mine is the C style Pro-stock with 1-3/4 primaries and a Quiet Riot baffle,"disc only"..Go for it, I don't think you will be disappointed at all,that is if you don't mind a little volumn,and I can almost guarantee you will love the sound..
I listened to a bunch of pipes before I decided on this one, I only wanted to drop $800.00 one time..LOL
95" BRANCH #4 heads
HQ575g cams
RB Racing C style prostock
DURWOOD is offline   Reply With Quote
Old 10-22-2009, 10:27 PM   #7 (permalink)
Thanks everyone I had heard that the quiet riot baffle people were having some legal trouble and could not sell any until straigtened out. Their web site is still up although and so is the price $129 bucks. So from what I gather go for the Pro Stock and have no worries for a bagger.
06 CVO 113 Ultra
SE MVA Heads
SE 251
SE 50mm TB
SE 10.5:1
ThunderMax ECM
Zipper A/C
AIM 92T VPC
D&D Fat CAt
3.37 Final Gearing
Old 10-23-2009, 12:04 AM   #8 (permalink)
TheNowhereman's Avatar
Legal stuff is long gone now.
They sell both types, the single hole or the multi hole.
I tested both on my 127 and went with the single hole unit.
Smaller engines under 100 inches would do better with the multi hole unit.
I makes the RB pipe just about perfect if you like torque, HP and sound.
If you want a quiet set up, don't go this route.
Nowhereman who else?
Old 10-23-2009, 04:15 PM   #9 (permalink)
qtrracer is on a distinguished road
BW if it were me and it isn't , I'd go LSR reg baffled 5 inches longer turn out rotated 45 degrees in whatever finish you want and when you call you can ask about primary tube size then. No offense to Nowhereman meant at all but I would not add any thing to the system. The Prostock is evil loud if that is what you want, the baffled LSR is pretty fn loud when you jump on it but not too bad when you are just cruising. This info is worth exactly what you paid for it...nothing.
08 SG 103" SE MVA Heads SE 10.5 Pistons SE 251 Cams SE 58 mm TB RB Racing 2-1
qtrracer is offline   Reply With Quote
Old 10-23-2009, 05:42 PM   #10 (permalink)
RK CRAIG is on a distinguished road
MEN,
LSR !!! Over rated !!! PERIOD !!!
RK CRAIG is offline   Reply With Quote
Old 10-23-2009, 07:24 PM   #11 (permalink)
laserp's Avatar
Originally Posted by RK CRAIG View Post
MEN,
Who's over rating the LSR? Have you had one?
You have a D&D fatcat don't you...
Old 10-23-2009, 07:32 PM   #12 (permalink)
I couldn't hear RK he was too far behind me, what'd he say?
Old 10-24-2009, 12:07 AM   #13 (permalink)
DURWOOD's Avatar
MEN,
That is exactly why there is more than one choice of exhausts.There are other 2-1s I don't like, but thats my choice,and believe me, I heard enough tractor sounding systems to guide me where I wanted to be.
Have you checked out bowsharley's sheet? Looks pretty impressive to me,I think it wen't over 120tq with a 107.
Throw that in with superior quality,fit and finish..I just don't see over rated,thats JMO.
95" BRANCH #4 heads
HQ575g cams
Old 10-24-2009, 12:25 AM   #14 (permalink)
DURWOOD's Avatar
I teetered back and forth between the baffled one and the
pro-stock and when Laser went baffled LOL,I figured what the hey,now we can have an A and B comparison.
95" BRANCH #4 heads
HQ575g cams
Old 10-24-2009, 01:33 AM   #15 (permalink)
that doesent say much for the lsr. i have a fat cat and the tq on my bike is hitting 130.. so thats that.. ill stick with fat cat
08 crossbones
hillside 107
woods tw8 cams
s&s roller rockers
s&s adj pushrods
larger injectors
vp92t
hillside air filter
230 ccp
hillside cycle...
