05-22-2009, 10:49 AM
bagger 2 into 1
Sorry if I started this thread in the wrong area. I was curious. I have a white bros. e-series 2 into 1 on my bagger. I bought it about seven years ago when I did the 95" motor(twin cam). I have since put in a 124" and have been using the same pipe. Has another pipe come out that would significantly improve performance over the old e-series? Keep in mind I like strictly 2 into 1 pipes.
Home of the 9 second street ridden 1130cc VRod
NOTICE: Info I post may be correct and relevant to threads posted in. Yet I may have learned this info else were and am just sharing it in a public forum for other members benefit. I am not responsible for any tantrums or fits you may have because it was read else were on the world wide web!
05-22-2009, 11:39 AM
mooooving out!
That pipe is the Holy Grail of pipes for 88-95" builds.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
05-22-2009, 12:40 PM
sure. RB racing, JBV racing make some badass 2 into 1s that will produce more than the white bros can.
Just depends if your willing to spend some coin and like the looks.
 Nowhereman who else?
05-22-2009, 01:24 PM
what about D&D.........
05-22-2009, 01:48 PM
Moneygreen
With a 124 I would suggest a D&D Boarzilla!!!! What kind of heads & comp are you running?? What cam do you have???
Craig G.
05-22-2009, 02:51 PM
Its a crate motor. So my GUESS is that its somewhere around 10.0:1?? Stock S&S heads and pistons. I believe the cams are 640's
Whats your suggestion????
05-22-2009, 03:34 PM
How much of a hp/tq gain would I see from one of these "badass" pipes vs. the E-series? With my current set up!
05-22-2009, 03:45 PM
Moneygreen
10.0 static is kinda low,JMHOP but they probably set it at that for reliability!!! I would definitely run the D&D Boarzilla!!!Whose going to tune it? & what tuning device are you using???
Craig G.
05-22-2009, 04:59 PM
i would think anything with a larger primary tube would yield some benefit. how much? hard to say for sure, let that puppy breathe!!! i'd look for something with a 2" primary, boarzilla don't quite make it. a recent conversation i had about the subject, to relate that motor to a v8, 124x4=496cubes, if you had a hot sreet car with a big block 500 cubes worth, would you stick a set of cheap 1 3/4" headers on it?
 107" axtel terrorist
thundertek cylinder heads
cams= not woods....
super "D"
loud d&d
05-22-2009, 06:27 PM
Moneygreen
The Boarzilla is a 1 7/8 primary tube stepping up to a 2 in tube,if I'm not mistaken!!! 1 7/8 tube should be plenty for the 124!!! Plenty of guys running the Boarzilla on 124ci motors with no problems!!!! With great results!!!
Craig G.
05-26-2009, 10:02 AM
Site Sponsor
i can get you those pipes for a great price... i don't think anyone beats me on D&D's.
05-26-2009, 10:55 AM
10.0 was my guess. Do you know what the S&S crate 124 are running for compression? How much power would I gain just swaping pipes? I dont have a tuning device other than a screw driver. I just got rid of the G and installed a HSR48 and I am running the S&S IST ignition with stock HD coil. I am tuning it.
05-26-2009, 10:57 AM
Based on your suggestion. Were would I find this pipe you refering to, with the 2" head pipe?
