03-09-2008, 11:51 AM
any comments on rush slip on mufflers
Hi
Just bought a 2008 FLSTC are the rush slip ons louder than stock do i have to re map the engine with these. I am still looking to change to vance and hines long shots but looking at a good cost savings any thoughts would be great
tm
03-09-2008, 01:25 PM
I have Rush mufflers with 1.75" baffles on my 07 Dyna and they are way louder than stock. You might get away without retuning if you don't do anything other than mufflers...you'll have to try it and see how the bike runs. I put my mufflers on before remapping and adding an air cleaner and the bike didn't run any worse than it did stock, but it didn't run very well stock either. After the air cleaner and canned Race Tuner map, the improvement in throttle response was very apparent.
03-09-2008, 02:02 PM
I have the 2 1/4 baffles in my Rush pipes (08 FLSTC). Very loud, but a very good quality sound. Deep rumble and crisp revs. But might be too loud for some tastes.
I would definitely get the smallest baffle available, if you plan to run without changing your fuel calibrations.
03-09-2008, 02:22 PM
i have modified rush slipons from fuelmotousa and they are almost as quiet as stock when idleing except a deeper tone on my bike . they are only significantly louder than stock when whacking on the throttle imo.
03-09-2008, 03:48 PM
I have the 2" . They sound great (imo). LOuder then stock with a real deep rumble
07 fatboy,103bb, hq 575 cams,bigboyz heads,stockheadpipes/rush mufflers,30tooth sprocket
03-09-2008, 04:36 PM
Just another Hog Jocky
Yep!, running them on my "07 Road Glide. Using 1.75 " baffle in left side,
2.25" in right side because of the unbalanced nature of stock FL pipes. Would probably use 2.25's a Dyna or Softail. These are extremely well made mufflers with easy to change baffles. They are loud but not anoying going down the road. Just right sound as far as I'm concerned.
My friends like me; everyone else thinks I'm an asshole. What's that say about my friends?
'07 Road Glide, 103 ci, Big Boyz "Bigger Valve" Street Port 85 cc heads, .030 quench for 10.2:1 cr, SE flat tops, Wood TW 6-6's, K&N air filter, Cobra/Fat Cat bastardized two-into-one exhaust, TMAT ECM with Auto-Tune.
03-09-2008, 06:30 PM
I put a set (2" baffles) on a buddy's 2007 Road Glide last fall. I advised him to add an SE intake and a power commander but he followed the dealer's advice and just did the pipes. 2007's have oxygen sensors so maybe that's why they work okay with the new muffler? He likes em they seem to run fine without remapping. They definitely had more bark than stock.
03-09-2008, 06:57 PM
Navy Vet, Civil Servant
Funny you bring this up -- researching with a stealer today -- he brought up rush too -- indeed said you can put on a version without doing a SERT or Stage 1 -- in a few months it will be interesting to hear how the pistons are doing out there -- let us know -- BTSOOM
03-09-2008, 08:10 PM
I paid.........did you??
I have a pair of Rush slip-ons for sale for a friend of mine. He bought them for his Heratige but changed his mind after he got them.
They look like a nice set of mufflers, well built, and they have a very good following online.
http://www.v-twinforum.com/forums/v-...-mufflers.html
Steve
95" Powered by Big Boyz Heads, Woods Cams, Doherty PowerPacc w/ Powervents,
TTS Mastertune, D&D Fatcat w/ Quiet Baffle, Hillside 46.5mm TB, & Cometic Gaskets
Built by Me, Tuned by Bean
03-09-2008, 10:01 PM
Steve
Thanks everybody gave me some thoughts to think about.
Tm
03-09-2008, 11:30 PM
How are they modified? Do they have different baffles?
I've got Rush slipons w/2" baffles on my Street Bob. Nice sound but I wish I could quiet them down some.
03-10-2008, 04:05 PM
yes they have different baffles .
03-10-2008, 11:20 PM
"Jane you ignorant slut!"
If you go with these I would not go larger than the 2" baffle or it will cost you torque in the lower rpm. There is a dyno sheet in the dyno section that will prove this.
Also on my Ultra I had the right side yellow from getting lean, even though all I did was change the mufflers. No air cleaner or tuner.
Chris
03-20-2008, 10:38 AM
I've installed lots of the rush mufflers without a tuner or air cleaner kit and the A/F ratio stayed the same as stock(14.7:1) on 07&08 bikes.
I use the 1 3/4"
03-20-2008, 10:42 AM
Are we having FUN yet?
Comment on Rush mufflers.......yes, they are not Vance and Hines.
I'm Just Sayin'...
K&N Air filter system
GMR Roller rockers.
Crane adjustable pushrods.
92.85 Torque 80.08 HP
Professional Rockat Surgen
Disclaimer.
