No lights/no start : V-Twin Forum: Harley Davidson Forums
Old 10-24-2012, 06:45 AM   #1 (permalink)
93FXSTC's Avatar
93FXSTC wants to know Dino or Syn?
No lights/no start
I started my bike 3 weeks ago and moved it to winter storage. Four days ago the weather was nice and wanted to go for a ride. When I turned the on switch no running lights and starter dead so I immediately thought battery and didn't think to try anything else but charge it up and hooked up the charger and went home. Two days later I went back, turned the switch and same deal: no lights no start. So I started troubleshooting.
The turn signals, horn, brake lights, oil and on lights all function fine. Didn't have anymore time as I needed to get ready for a road trip to Austin. I'm on that trip now in Lawton, Oklahoma today.
I'm starting this tread to get advise/suggestions of what it might be and how to diagnose/troubleshoot it down to the bad component. In the mean time I will search other posts for ideas also. Thanks,
Keith Mouser
Bountiful, Utah
93FXSTC is offline   Reply With Quote Quick reply to this message
Old 10-25-2012, 06:28 PM   #2 (permalink)
speedfreak wants to know Dino or Syn?
Keith Mouser
Bountiful, Utah
did you find any broken cabels/ bad connectors broken fuses?. there is also a thing called
circuit breaker 30A on my softail sits on the back on the mud gard
that bolted to the swing arm rhigt side behind the oil bag
just my 1 cent.
speed.
speedfreak is offline   Reply With Quote Quick reply to this message
Old 11-03-2012, 03:43 PM   #3 (permalink)
93FXSTC's Avatar
got back from my Austin road trip... the bike started right up ? I'm sure this isn't the end of the story.
Old 11-04-2012, 04:24 AM   #4 (permalink)
tussuck's Avatar
tussuck wants to know Dino or Syn?
Loosen and tighten all the circuit breaker bolts etc...
Sent from my iPhone using Motorcycle.com App
I prefer my engine blown not stroked!
D.L.R.A #1174
tussuck is offline   Reply With Quote Quick reply to this message
Old 11-04-2012, 09:05 AM   #5 (permalink)
Y2K
Y2K wants to know Dino or Syn?
And get some contact cleaner,clean battery cables and terminal ends etc,a soft wire brush is a good idea till things are shiny.
Very common problem,doesn't have to look dirty to be a problem,even a slight film of corrosion can cause trouble.
Y2K is offline   Reply With Quote Quick reply to this message
Old 11-04-2012, 09:16 AM   #6 (permalink)
Blackened wants to know Dino or Syn?
It does sound like you have a bad ground somewhere. Other than the above suggestions, check your ground wires, especially if they are aluminum.
Aluminum cables/wires have a nasty habit of wicking moisture and oxidizing inside the insulation, I've seen a couple older bikes that had more white powder than wire an inch or so up from the cable end.
Copper, no worries, just hit the ends with the wire brush as Y2K suggested.
'03 FXSTB - SOLD (GBNF)
'94 FXR
'14 Street Glide Special
Blackened is offline   Reply With Quote Quick reply to this message
