S&S V111 evo engine problems : V-Twin Forum: Harley Davidson Forums
Old 07-30-2012, 09:08 PM   #1 (permalink)
camster wants to know Dino or Syn?
Unhappy S&S V111 evo engine problems
I bought a complete S&S V111 engine with Super Stock ignition, and Super E carb. I installed it in a 1999 Fatboy with D&D Fat Cat exhaust. It accelerates fine but when cruising at a steady throttle it hesitates/bucks/jerks in all gears, most noticably between 1800 and 2400 RPM. I've had it dyno tuned and the intermediate and main jets are right, the idle mixture and the accelerator pump have been adjusted. A new coil has been installed, the plugs and plug wires are new. The float and needle have been checked. VOES is new. Any ideas? I had high hopes for this engine but am pretty disappointed.
camster is offline   Reply With Quote Quick reply to this message
Old 07-31-2012, 12:38 AM   #2 (permalink)
SirJYK wants to know Dino or Syn?
need more info
It sounds like a carb/intake problem. It could be a timing issue. More info is needed.
Thanks.
1999 California Motorcycle Company Softail Custom, S&S 88, RB Racing pro stock 2-1 exhaust. Super E. Daytona Twin Tec Ignition 1006. Wood W8 cam. New to me 2005 Electra Glide Classic, stock for now, but not for long...
SirJYK is offline   Reply With Quote Quick reply to this message
Old 07-31-2012, 12:41 PM   #3 (permalink)
What more info do you need? I can't do anything about timing because S&S seals the ignition and if you break the seal, the warranty is voided.
Old 08-01-2012, 02:53 AM   #4 (permalink)
tussuck's Avatar
tussuck wants to know Dino or Syn?
How is the chain? Or is it a belt?
I prefer my engine Blown NOT Stroked!
Sent from my FXR powered iPad
I prefer my engine blown not stroked!
D.L.R.A #1174
tussuck is offline   Reply With Quote Quick reply to this message
Old 08-01-2012, 09:27 AM   #5 (permalink)
Master Motorhead
Thermodyne's Avatar
Thermodyne is still riding a stock bike Thermodyne is still riding a stock bike Thermodyne is still riding a stock bike
First thing I'd do is fatten it up. You can start by making the idle a little on the rich side. Might not cure it, but should improve just a little. Don't worry about the idle. If it does help a little, go up on the intermediate jet. The juice that passes for gas these days tends to make em run skinny.
Thermodyne is offline   Reply With Quote Quick reply to this message
Old 10-13-2012, 07:32 PM   #6 (permalink)
JamesButler is reading this now saying WTF is this?
Did u ever find and fix the problem?
JamesButler is offline   Reply With Quote Quick reply to this message
Old 10-14-2012, 08:47 AM   #7 (permalink)
feguy1 wants to know Dino or Syn?
That motor needs a super g. Or my personal favorite, a 45 mikuni. Super e is too small.
2008 FXDF
1987 FXRP
1978 FX Low Rider
feguy1 is offline   Reply With Quote Quick reply to this message
Old 10-23-2012, 08:40 PM   #8 (permalink)
speedfreak wants to know Dino or Syn?
s&s v111 evo engine problems
camster i wondering the same as james butler did have you
fix that motor what was the problem whith it?.
speed.
speedfreak is offline   Reply With Quote Quick reply to this message
Old 10-28-2012, 12:04 PM   #9 (permalink)
camster how was the fitment in the frame any problems?.
com on and let us know did the bike runns fine now?
im very curious on your answer thinkin of buy a v111 mill to my softail 99. for my last money..
speed
Old 10-30-2012, 11:27 AM   #10 (permalink)
grndpndr's Avatar
grndpndr wants to know Dino or Syn?
My engine will buck in all the gears at about the same rpm range as stated above...I think my problem is keeping it on top of the .600 cam at those rpms.
grndpndr is offline   Reply With Quote Quick reply to this message
Old 10-30-2012, 07:15 PM   #11 (permalink)
what engine do you have in the bike?
maybe a another cam that is litte
smaller in yours but what i now
im no engine tuner.
speed
Old 10-31-2012, 08:50 AM   #12 (permalink)
grndpndr's Avatar
im no engine tuner.
speed
Its an an Evo. Its a one off build,...delkron cases, axtell c.i. jugs, edelbrock heads...
It had dual carbs on it but I never could get both cyclinders where they needed to be fuel/air wise at the same time. So I am in the process of putting a single carb on it.
It runs great, just have to stay on top of the cam lobes to keep it happy....
It doesn't like to be in town traffic at all and it wants to pass everything but a gas station!! Last I checked the fuel milage it was just under 20 mpg....
I agree with you tho, a little lower cam may be in the works before to long.
Old 10-31-2012, 08:52 PM   #13 (permalink)
a friend of mine had dual mickuni carbs a few years back on a s&s124evo
dident runns fine att all he put back the s&s single carb again dont now
if it is a super g or d on those after that the bike runns strong as a
train. the mpg is vent down to. what i remember.
maybe your bike being better in town whith the single
carb you are in process to putting on. just thinking loud
im no tuner you now.
speed
Old 11-01-2012, 12:05 PM   #14 (permalink)
"D"
"D"'s Avatar
"D" wants to know Dino or Syn?
I'd like to know what the original poster found with his S&S V111. I am in the process of dropping one in my '84 FXST.
As this engine is advertised as having a shorter profile than the stock Harley 80" are the exhaust ports any lower? The '84 has a kick starter and thus can't stand much pipe movement to still fit the pipes around the kicker.
Probably a dumb question.
D
1984 FXST "The original"
2016 FLSTFB Fat Boy Lo
"D" is offline   Reply With Quote Quick reply to this message
Old 11-01-2012, 10:09 PM   #15 (permalink)
i want to know that to.
d let me know how things turns out for you
whith the 111" im pretty sure i going to buy one
for my 99 fxst
speed
