EV13 or EV27? - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 02-25-2012, 08:02 PM   #16 (permalink)
>>> The Curmudgeon <<<
barrybasinger wants to know Dino or Syn?
Originally Posted by <G Man> View Post
That's great info. I was leaning toward the EV13 as it is recommended for my type of use by Andrews. I only went with the EV27 because I do intend to go with 9.5:1 pistons later this year and figured I would just buy one cam now and not another later.
>>> AS LONG AS YOU KNOW THAT THE PRESENT SITUATION IS NOT OPTIMIMUM, THAT MAKE LOT'S OF $EN$E.
Where in TN are you? I am in Candler, NC (about 13 miles west of Asheville) and my mom lives in Sevierville, TN. My wife and I make several trips a year over there and the Gatlinburg area.
>>> MIDDLE TN, NEAR THE AL BORDER.
Just a curious question: with a stock ECM, the revs are limited to about 5200 anyway so who cares if you "run out of breath at 5000" unless you are flashing or replacing ECM? Is this a valid question?
>>> NOT ONLY IS IT VALID, IT INDICATES GOOD THINKING. INI TURN, THAT LEADS US BACK TO CAMS: IF YOUR COMBINATION PRODUCES TQ DOWN LOW, AND MOST ALL OF IT'S POWER BEFORE 5200 RPM, WHY REFLASH?
BTW, IF YOU NEED MORE RPM, IF YOU USE THE PCIII-USB YOU CAN RAISE THE REV-LIMIT WITHOUT A RE-FLASH.
I have a PC3 USB installed. Should I hit the dyno for a tune after I get the cam in or just find a good map from the dynojet web site? ... What about these guys that do tuning in their trailers at rallies? ...:
>>> IF YOU FIND A MAP THAT LISTS MODS SIMILAR TO YOURS, YOU'LL PROBABLY NOT BE ABLE TO TELL ANY DIFFERENCE BETWEEN IT AND A CUSTOM MAP IN REAL LIFE. AS TO THE GUYS IN TRAILERS: A GOOD FRIEND OF MINE RAN ONE FOR YEARS. HERES'S WHAT I'D SAY ABOUT THEM. THEY ARE A BUSINESS, AND THEY DO NOT HAVE TIME TO FART AROUND WITH EVERY LITTLE DETAIL DURING A TUNING SESSION. MY FRIEND HAD DONE SO MAY BIKES OVER THE YEARS THAT HE PRETTY MUCH KNEW WHAT WAS GOING TO WORK 99% OF THE TIME. HE DID THAT, MADE THE RUN TO CONFIRM THE RESULTS WERE IN THE RANGE EXPECTED, AND YOU WERE DONE. IF HE'D MADE DOZENS OF RUNS FOR YOU, ODDS ARE THAT HE'D FIND A COUPLE MORE HORSES IN THERE SOMEWHERE, BUT IT WOULD COST YOU--AND HIM--WAY MORE THAN IT WAS WORTH. THERE WILL CERTAINLY BE EXCEPTIONS, BUT I THINK IN GENERAL THE "TRAILER GUYS" GIVE ENOUGH VALUE FOR MONEY TO MAKE THE A VALID CHOICE.
BB
You may find this interesting:
https://sites.google.com/site/harleyrealstreet/
Five Simple Rules:
- Free Your Heart From Hatred
- Free your Mind From Worries
- Live Simply
- Give More
- Expect Less
"Livin' Dreams and Makin' Memories"
Brian C. Basinger 1944 - 2011
R.I.P., Bro'
barrybasinger is offline   Reply With Quote Quick reply to this message
Old 02-25-2012, 09:30 PM   #17 (permalink)
The Best Me I Can Be
Homesick's Avatar
Homesick just installed tassels Homesick just installed tassels Homesick just installed tassels Homesick just installed tassels
Originally Posted by barrybasinger View Post
If I was riding an Ultra and I planned to ride it like one, I'd add the 23, an SE filter package, and a set of slip-on mufflers from Kerker, S&S, and a few others.
If I was riding a Road King and planned to ride it "mixed use", i.e. a mix of shorter trips but mostly local stuff, I'd probably lean towards a 13 if the rest of the stuff was the same as above.
The 23 is a very mild cam that will probably net you a little more TQ and power than stock, but it's for dressers that are ridden like dressers.
Thank you sir.
Keep The Change
Reader of Ayn Rand
Inventor of the FXR Cult Secret Decoder Ring
A**hole Merit Badge winner
Missing Link Merit Badge winner
Badge of Honor winner
FXRT- Hubba Hubba
Oct '14 RotM
Homesick is offline   Reply With Quote Quick reply to this message
Old 03-03-2012, 12:50 PM   #18 (permalink)
Barney Fife - Fake Biker
<G Man>'s Avatar
<G Man> joined the Live to Ride club <G Man> joined the Live to Ride club <G Man> joined the Live to Ride club <G Man> joined the Live to Ride club
Originally Posted by tweaked1973 View Post
I have a real similar cam to the EV-27 in my 97 FLH. (SE-3 has .008" more lift, but everything else is identical) I love the cam. It is not quite as strong as the EV-13 off the line, but it is great for not having to downshift to pass trucks etc, even when loaded.
Since you listed the PCIII you must have the old MM EFI. Look at your injectors and see if they have red tops or black ones. The black top injectors will not flow enough fuel to feed wither the EV-27 or EV-13. Red top injectors flow 46% more fuel. If you install the red tops the bike will barely even run until the new fuel MAP is put in. (From running too rich) The HD Stage II kit included a new flash cartridge that had to be programmed into the ECM when the red tops were installed. The PCIII if I recall can not subtract enough fuel to make it run correctly with the base fuel MAP. You will also need to adjust the spark advance and total timing.
If you need them I have a whole good induction unit as a spare, plus I have the entire induction unit just removed from my FLH with the TPS and air bleeds dialed in, both with red top injectors. I also have the entire factory ecu with the Stage II program installed.
I can also answer some of the questions that may pop up since I did several real similar engine combos.
What kind of deal would you offer me on the Stage 2 flashed ECM?
G Man
Meddle not in the affairs of dragons for you are crunchy and taste good with ketchup.
Quotes found on the internet are not always accurate. - Abraham Lincoln
Silence is golden , duct tape is silver.
Stay back 200 feet - not responsible for damaged feelings.
<G Man> is offline   Reply With Quote Quick reply to this message
Old 03-03-2012, 04:01 PM   #19 (permalink)
jsbridgew wants to know Dino or Syn?
i've got a 91 evo with heads by Don Dorfman at Deweys, SE pistons at 10:1, an EV27, and a Baker compensator... and this thing moves very nicely
no complaints
jsbridgew is offline   Reply With Quote Quick reply to this message
Old 03-03-2012, 05:46 PM   #20 (permalink)
tussuck's Avatar
tussuck wants to know Dino or Syn?
Have you looked at the Andrews EV3? It's a nice all round cam.
Sent from my FXR powered iPad
I prefer my engine blown not stroked!
D.L.R.A #1174
tussuck is offline   Reply With Quote Quick reply to this message
