evo coil wiring : V-Twin Forum: Harley Davidson Forums
Old 08-12-2011, 01:00 PM   #1 (permalink)
Wiggim wants to know Dino or Syn?
evo coil wiring
does anyone know where i can get a wiring diagram for the coil setup or why the bottom connection on my coil has 3 wires( red, blue, green) running to it and top only has 2 wires(white or tan with a blue stripe, red) and is that right or not?
Wiggim is offline   Reply With Quote Quick reply to this message
Old 08-15-2011, 11:55 AM   #2 (permalink)
or a place i can find a wiring diagram to check it, its gonna take about 2 weeks before a shop manual will be here so any help would be greatly appreciated
Old 08-15-2011, 12:30 PM   #3 (permalink)
LexKing's Avatar
LexKing wants to know Dino or Syn?
Someone might have the information that you need, if they knew the model and year of the bike. Just sayin......
Regards; Lex
1998 DYNA WideGlide
2003 RoadKing Classic
2005 Heritage Softail Classic
Previous Travels
LexKing is offline   Reply With Quote Quick reply to this message
Old 08-18-2011, 09:48 AM   #4 (permalink)
1995 dyna wide glide,
should have done that in the begining... sorry my fault
gonna go bang head against wall...lol
Old 09-08-2011, 07:00 PM   #5 (permalink)
anyone able to help or am i just
Old 09-08-2011, 08:34 PM   #6 (permalink)
leeboy03 wants to know Dino or Syn?
what kind of ignition are you runnin?
leeboy03 is offline   Reply With Quote Quick reply to this message
Old 09-08-2011, 08:37 PM   #7 (permalink)
screaming eagle dual fire with a accel super coil
Old 09-16-2011, 07:28 AM   #8 (permalink)
grndpndr's Avatar
grndpndr wants to know Dino or Syn?
I'd get in touch with the coil mfg. They can give you any specifics.
grndpndr is offline   Reply With Quote Quick reply to this message
Old 09-17-2011, 09:26 AM   #9 (permalink)
In disguise
FXR2's Avatar
FXR2 wants to know Dino or Syn?
Are you saying that the body of the coil itself has three low-voltage (small, threaded) terminals? If so, you have a single-fire coil, which is not compatible with your dual-fire ignition module. A dual-fire coil will have two, low-voltage wire connections while the single-fire coil has three.
Dual-fire:
Single-fire:
Or, are you looking for a diagram of where the single-fire coil wires go? There are actually 4 wires at the coil:
You nonconformists are all alike.
April 2016 ROTM Winner.
FXR2 is offline   Reply With Quote Quick reply to this message
Old 09-18-2011, 12:41 PM   #10 (permalink)
Obiejuan's Avatar
Obiejuan wants to know Dino or Syn?
Blue wire connects to front cyclinder, Power from your kill switch on your handle bar controls goes to the middle of the coil and the other wire goes to the rear cyclinder. Thats according to my instructions from my Ultima/Dyna ignition instructions.
Obiejuan is offline   Reply With Quote Quick reply to this message
Old 09-20-2011, 10:46 AM   #11 (permalink)
its a dual fire set-up , same coil as the first picture
Old 01-06-2016, 12:47 PM   #12 (permalink)
randyyates929 wants to know Dino or Syn?
Looking for chopper wiring diagram for 1995 Evo I don't nothing about wiring need a pic to go off of something like this with the cdi box included
randyyates929 is offline   Reply With Quote Quick reply to this message
Old 01-06-2016, 12:49 PM   #13 (permalink)
This is what I got need cdi box included in?
Old 01-06-2016, 08:14 PM   #14 (permalink)
tall terry is reading this now saying WTF is this? tall terry is reading this now saying WTF is this?
That diagram is for a single fire ignition
From memory, the coil has no + or -, just the right wires need to be connected to the right side of the coil.
On 1 side, a white wire from the right switch house, also a white wire from the (stock) ignition module
On the other side of the coil, a blue from the stock ignition module, and a pink to the tachometer, if the bike has 1.
This is all that's required on the primary wiring to run.
There will be 8 wires at the module connector
Red to sensor
Green to sensor
Black to sensor
Blue to ign coil
White to ign coil
Pink to tach
Purple to voes if no voes, ground this wire, for rule advance, leave loose for retarded timing (ground it)
Black to voes ground
The first 5 are necessary to run, the last 3 are not, make sure the pink is covered if no tach on bike
tall terry is offline   Reply With Quote Quick reply to this message
Old 01-13-2016, 09:01 PM   #15 (permalink)
Thank you ..........
