127" Ultima Motor Problem : V-Twin Forum: Harley Davidson Forums
Old 11-05-2009, 09:23 PM   #1 (permalink)
tmwmoose wants to know Dino or Syn?
I had a 127 ultima dropped of today thats in a nice custom build new motor and is shuting down when hot will start back up but just for a second then off again . Motor has to cool down to run again . Customer says motor runs extremly hot. He has replaced the ignition , coil , key switch,ran battery strait to coil, checked batt conections. He has also left the gas cap loose and reroute the fuel line. he says he has electrics when it happens and asumes the ignition is still on. Will be looking at it in next few days myself sounds like he's covered the electrics its the heat thing I'm wondering about and whats its doing to the mikuni maybe . Any Ultima owners out there that have experineced this ?
tmwmoose is offline   Reply With Quote Quick reply to this message
Old 11-05-2009, 10:42 PM   #2 (permalink)
Moneygreen
arealinvestor's Avatar
That doesn't sound good!!! Are you an Indy??
T-Man gear crank set
Jagg 10 row oil cooler
K&P engineering oil filter
To much more to list!!!!!!
Old 11-05-2009, 10:45 PM   #3 (permalink)
Premium octane member
TXCHOP's Avatar
Try taking off the ignition cover and see if it helps. Especially it the motors running really hot, the heat can kill electronic quick. If it works, tune it, and space the cover out a bit.
S&S T124
Old 11-05-2009, 10:48 PM   #4 (permalink)
Otto wants to know Dino or Syn?
sounds like it would be fuel related if the electrics are good stuck float plugged needle seat ect unless it's hanging valve ect but that would be noisey
Otto
my opinions are mine and subject to my way of thinking disagree if you will or not
Workin to play
Otto is offline   Reply With Quote Quick reply to this message
Old 11-05-2009, 11:30 PM   #5 (permalink)
Will-Run wants to know Dino or Syn?
Please suffer a dumb question , what is an Indy? exactly?.
Thanks.
Will-Run is offline   Reply With Quote Quick reply to this message
Old 11-05-2009, 11:35 PM   #6 (permalink)
Moneygreen
Thanks.
A private Harley Mechanic/Technician that usually works for himself & not a dealer!!!!
Old 11-05-2009, 11:51 PM   #7 (permalink)
Yes I'm a indy ,thanks for the tips guys I'll be running blowers and fans while getting the motor hot don't have all day to ride these senerio's if ya know what I mean and get stranded as well. I plan on running my test neon sparkplug wires to moniter spark but I'm guessing more toward fuel again appreciate the help will update!
Old 11-06-2009, 01:05 AM   #8 (permalink)
pwmorris is reading this now saying WTF is this?
Is he running a Cannister or any other type of EPA emmisions eqpt? -possible vapor lock as a bike runs a while and the bike shuts off. I saw it on a Buell and another custom...after I pulled the set up off it was good to go.
What type of bike is it in-is it a custom build-many custom builds have wires, etc, routed near hot points on the motor-as heat builds-shorts out.
Where exactly is the coil/ignition mounted-plenty of cool air around them-plenty of clearance next to the motor?
Sure it is just when hot and not just after he has been riding a while? In that case I am thinking sediment in the petcock screen causing fuel starvation-bike rides awhile, and debris from tank obstructs fuel flow thru petcock. Bike shuts off, debris settles, and re-starts again, then after a while shuts off again.
Carb-How exactly is the fuel line mounted from tank to carb-running away from motor? Between the cylinders? Using a sleeve to keep heat from fuel?
Member S&S 11, 10, 9 Second Clubs (1 of 9 Worldwide)
Multi Harley Race Winner
3 X Best Of Show
8 X Horsepower Shootout Winner
NHRA #SP781
pwmorris is online now   Reply With Quote Quick reply to this message
Old 11-06-2009, 08:06 AM   #9 (permalink)
gsxrboy96's Avatar
gsxrboy96 wants to know where he is and how he got here
Try this, this sounds like your problem.
gsxrboy96 is offline   Reply With Quote Quick reply to this message
Old 11-06-2009, 08:58 AM   #10 (permalink)
Thread Ender
Pikeslayer's Avatar
Confirm that the fuel tank is vented. Will it run with cap off?
2007 Street Glide
Old 11-06-2009, 09:07 AM   #11 (permalink)
Totenkopf is reading this now saying WTF is this?
Based on the description and if the ignition module is staying on during the event, I agree with Otto and Paul, it's a fuel delivery issue. Otto has been running a 127 for 2 years in a custom bike, if the AFR is correct and the Mik is setup correctly for all the transitions, they don't run any hotter than a normal motor. And it sure is a fun motor!
One thing to be aware of, Otto has noticed over the last couple of years that the oil pump they were shipping with the motor for a while is a clone of a Jims iirc, Ultima unfortunately even cloned the flaws in that design. When he sells these motors to a customer, he checks and corrects the oil pump as necessary to make sure they work correctly. He's had other 127's come in for repair that folks had bought and installed and didn't know about the pump issue. This is where internet shopping/buying will bite you in the azz every time if you don't have experience.
Totenkopf is offline   Reply With Quote Quick reply to this message
Old 11-07-2009, 09:17 AM   #12 (permalink)
SnailTraX wants to know Dino or Syn?
What flaws
Are the flaws still there? Is this still a concern? Can you describe them?
One thing to be aware of, Otto has noticed over the last couple of years that the oil pump they were shipping with the motor for a while is a clone of a Jims iirc, Ultima unfortunately even "cloned the flaws in that design." When he sells these motors to a customer, he checks and corrects the oil pump as necessary to make sure they work correctly. He's had other 127's come in for repair that folks had bought and installed and didn't know about the pump issue. This is where internet shopping/buying will bite you in the azz every time if you don't have experience.
SnailTraX is offline   Reply With Quote Quick reply to this message
Old 11-07-2009, 09:31 AM   #13 (permalink)
rob71458's Avatar
rob71458 wants to know Dino or Syn?
Vapor lock, Fuel boiling in the bowl?
rob71458 is offline   Reply With Quote Quick reply to this message
Old 11-07-2009, 10:54 AM   #14 (permalink)
Antonio Pendejo wants to know where he is and how he got here
Start the motor and while it is still cold put a heat gun to the pickup in the cone.
AP
Antonio Pendejo is offline   Reply With Quote Quick reply to this message
Old 11-10-2009, 08:02 PM   #15 (permalink)
127" Ultima Motor Problem found!!
Finaly got to the bike today checked timing first and then got it running .It never got hot like the customer said but I understand him here in Fl @ 95 degree's hot sun yeah it feels hot . Well oil is circulating and pressure is good so here I am locked inside rainning good outside all I can do is rev and idle with the blowers out front this bike is way to long for the dyno. I got to thinking about the get hot and shut off deal and thought this sounds like a charging problem maybe with a damn good battery. Out comes the meter and wow almost 18 volts jeez whats with that well I got it to shut off after 45min of playing and then put a new regulator in place and it would run with out shutting off did this back and forth to make sure and walla fixed called dyna tech (2000i) and they said there unit would shut down @15v well whatever turned out to be a good rainy day after all thanks guy's for the help!!!
