OEM 'L' Cam vs. 'N' Cam : V-Twin Forum: Harley Davidson Forums
Old 08-15-2009, 05:58 PM   #1 (permalink)
JoeHall wants to know Dino or Syn?
I am considering replacing the OEM 'N' cam in my new (1999) crate EVO motor, with a 1988-92 vintage 'L' cam. Looking at the specs for the two cams, it definitely appears the L is hotter, but I wonder how much hotter, and if gas mileage would be better or worse. Has anyone ever swapped an L with an N cam?
Thanks,
Joe
JoeHall is offline   Reply With Quote Quick reply to this message
Old 08-15-2009, 06:03 PM   #2 (permalink)
Dave63's Avatar
Dave63 wants to know Dino or Syn?
http://www.nightrider.com/biketech/h...o_byman_ql.htm
.472 (N) vs .495 (L) lift. Some other little things, but not as stuffy as the N grind. I believe the N grind was HD's worst EPA cam made.
Dave
Dave63 is offline   Reply With Quote Quick reply to this message
Old 08-15-2009, 07:00 PM   #3 (permalink)
60195 wants to know Dino or Syn?
Or you could put a mild performance cam in it, maybe an EV27, and be much better off.
60195 is offline   Reply With Quote Quick reply to this message
Old 08-15-2009, 08:07 PM   #4 (permalink)
98 FLHX's Avatar
98 FLHX wants to know Dino or Syn?
My thoughts exactly...tons of mild options out there.
You have nothing to lose, and plenty to gain.
"Si Vis Pacem, Para Bellum"
______________________
10:1 JE Pistons
Heads by GMR Performance
Ness Big Sucker
Mikuni HSR 42
V-Thunder 3040 Cam
Dyna 2000 Ignition
Thunderheader
_______________________
98 FLHX is offline   Reply With Quote Quick reply to this message
