S&S 113 Questions : V-Twin Forum: Harley Davidson Forums
Old 10-01-2008, 11:13 PM   #1 (permalink)
andersun16 wants to know Dino or Syn?
S&S 113 Questions
I'm new to the world of American V-Twins. Just bought a chopper with a 113 S&S Motor. Does anybody know what this motor is based on? Evo? Twin Cam? I'm just trying to figure out which oil filter and other odds and ends will fit.
andersun16 is offline   Reply With Quote Quick reply to this message
Old 10-01-2008, 11:22 PM   #2 (permalink)
Moneygreen
arealinvestor's Avatar
113
If i had to guess I would say its based on the TC!!! Does the motor have 1 or 2 cams????
T-Man gear crank set
Jagg 10 row oil cooler
K&P engineering oil filter
To much more to list!!!!!!
Old 10-02-2008, 09:26 AM   #3 (permalink)
DILLIGAF
RattFXR wants to know Dino or Syn?
Generally the S&S sidewinder motors are based off the tried and true Evo design. There are a few ways to check. If there is no oil pump on the outside of the motor (aft of cam cover) its a TC. Meaning if the oil lines go in to the case. Other minor things such as rocker boxes having 4 screws (evo) or 6 (TC). However you can find after market evo rocker boxes that look like TC. Oil pump is the most obvious thing to tell you over the net. Find someone with a pre 99 bike and look at the motors, if there are major differences then you have a TC. 99% sure it's an evo though.
RattFXR is offline   Reply With Quote Quick reply to this message
