Andrews EV38 : V-Twin Forum: Harley Davidson Forums
Old 04-18-2008, 03:43 PM   #1 (permalink)
Harleyd wants to know Dino or Syn?
Andrews EV38
Does anybody know anything about the Andrews EV38 cam and how it performs compared to the EV27. It would be going into a FXST. The 38 comes in at 2200 vs the 27's 2000.
Harleyd is offline   Reply With Quote Quick reply to this message
Old 05-08-2008, 03:21 PM   #2 (permalink)
yeehaw wants to know Dino or Syn?
Andrews ev 38
Ev46 is the largest cam you can bolt in while using stock valves. Fast open
and close ramps. High static compression pressure allowing 6000+ RPM, use with stock heads and lifters. Best choice I think, without changing stock valves. This cam works better in the higher RPM's.
Ev27 pulls from 1500-6000 RPM range.Good as well.
yeehaw is offline   Reply With Quote Quick reply to this message
