starter clutch : V-Twin Forum: Harley Davidson Forums
Old 05-21-2007, 02:29 PM   #1 (permalink)
Obsolete Rider
RidingJerry's Avatar
RidingJerry wants to know Dino or Syn?
starter clutch
Looks like I am going to join the ranks of those needing to replace the
starter clutch.
Just started last week. Hit the button and starter motor spins but nothing
happens. Have to hit the button a couple of times for the engine to
start spinning.
Anyone happen to have parts numbers for the starter clutch parts for
a 98 evo?
Guess I need to read up in the manual a little.
1998 Obsolete EVO Springer
Now boasting the Al Gore enviromentally friendly engine.
In the South, it is "Merry Christmas".
RidingJerry is offline   Reply With Quote Quick reply to this message
Old 05-21-2007, 05:53 PM   #2 (permalink)
ASA Lives
Ultra89Rider's Avatar
Ultra89Rider wants to know Dino or Syn?
I got mine off eBay. It was at a great discount over Harley and from the part I used, is great! a lot less than the Factory part price,even with the shipping. The Harley part number is 31663-90. It's the same part used from 1990. Good luck.
la'Hom Ho'neH jorDe' vestai-VamPyr
wa'DIch, IKRV Hurgh HaP, Ring of Fire Fleet
Order of the Bat'LetH
"lIgh tlhab"
(Ride Free)
Ultra89Rider is offline   Reply With Quote Quick reply to this message
Old 05-22-2007, 07:46 AM   #3 (permalink)
Obsolete Rider
Thanks for the heads up.
Boy, the service manual sure is lean on discussing the starter removal/
assy.
Looks like the starter has to come off rather than go in through the primary.
I guess I'll pull the battery and then pull the bolts for the oil tank (softail)
to get some hand room. Did you replace the o ring called for in the manual?
Old 05-22-2007, 07:56 AM   #4 (permalink)
Longtime Asphalt Cowboy
Texan's Avatar
Texan wants to know Dino or Syn?
Originally Posted by RidingJerry
Looks like I am going to join the ranks of those needing to replace the starter clutch.
start spinning.
a 98 evo? Guess I need to read up in the manual a little.
Hey Jerry, see some of the previous post on this issue. Like you'll read, I replaced the starter clutch on my '96 Evo for $50.00 vs the $100+ that Harley wants AND it's a much stronger setup.
o~\o
"Ya know I haven't been everywhere but it's on my bucket list"
Texan is offline   Reply With Quote Quick reply to this message
Old 05-22-2007, 11:12 AM   #5 (permalink)
Obsolete Rider
Thanks again for the heads up.
Looks like the all balls clutch is half the price of the oem.
sounds like a no brainer.
Old 05-25-2007, 06:30 AM   #6 (permalink)
Obsolete Rider
Glad the EVO bump starts
Well,
The starter clutch decided to completly quit at work yesterday.
I had thought it would just be aggravating until I replaced it.
Going to get a clutch today from the local Indy.
Had to bumb start the springer in the parkig lot at work to get home.
Sure am glad I learned how to do this with the XLCH. (not that it is
too hard)
Started worked perfectly well yesterday morning but wouldn't grab
at all at lunch or in the afternoon.
Warning!!! If your starter clutch is starting to go, replace it. I wasn't expecting it to give up the ghost so quickly. From the first time it didn't
work properly till failure was only about 10 starts.
Old 05-26-2007, 02:52 PM   #7 (permalink)
bonnie john wants to know Dino or Syn?
yep, same for me on my fatboy about 3 years ago ...
Well,
too hard)
bonnie john is offline   Reply With Quote Quick reply to this message
Old 05-28-2007, 06:50 AM   #8 (permalink)
Obsolete Rider
update
Made enough time Sunday to tear it down.
I finally decided to pull the oil tank so I could see what I was doing.
(now that I've seen it, I think it can be done without pulling the tank)
My Indy got me the wrong clutch. The 98 softail uses the shorter
of the two clutches, just so you know)
Once I get the correct clutch, it should be a pretty straight forward
assembly.
BTW, the clutch works properly in your hand with the little bit of torque
you can make with your fingers.
