inner primary leak : V-Twin Forum: Harley Davidson Forums
Old 03-19-2007, 06:11 PM   #1 (permalink)
scooter coot
brittfan's Avatar
brittfan wants to know Dino or Syn?
inner primary leak
To make a long story short, I discovered this weekend that what I thought was an outer primary leak is really an inner primary leak.
I'll be pulling the inner this weekend to take a look, but it is unknown terrirtory for me. I looked at "the book" and it seems pretty staight forward. Any tips from any body???
Wish me luck.
I was born here and I'm too stupid to move!!!
brittfan is offline   Reply With Quote Quick reply to this message
Old 03-19-2007, 07:43 PM   #2 (permalink)
road_king's Avatar
road_king wants to know Dino or Syn?
This might help
road_king is offline   Reply With Quote Quick reply to this message
Old 03-20-2007, 09:41 AM   #3 (permalink)
B767capt wants to know Dino or Syn?
I had a leak on my 03 SERK. I also put in a Baker 6 speed and found something that I would highly recommend. The inner primary bearing rides on a race that is on the tranny shaft. This can work its way in on the shaft and cause problems. High torque motors and or too tight of a drive belt will cause this. Flexes the shaft. While you have the inner primary off, look at the heavy duty bearing that Baker sells for this application. The race is contained in the inner primary bearing it self, all one piece. Since it is all one piece, it can't work its way in on the tranny shaft. A much better setup. The bearing comes with the inner seal too. It's about 40.00 total. I got the race off the shaft by grinding a groove in it with a dremial tool (sp?) and tap with a punch. My race had walked in so the normal tool wouldn't grab it. Drag Spec. sells the Baker bearing too. Jenni sells it for 20% off.
Bill
B767capt is offline   Reply With Quote Quick reply to this message
Old 03-24-2007, 09:11 AM   #4 (permalink)
Race
S&S makes a good set-up too.
