PerformanceOilTechMotorcycle.com Classifieds!KomodoGear.comEagleRiderSportbikeTrackGearCheapCycleParts.comHD PipesKewlMetal.comStoneyStraps.comRacerPartsWholesale
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > Technical Discussion Forums > Evolution Engine Technical Discussions
PerformanceOilTech
Old 10-06-2008, 10:28 PM   #16 (permalink)
Longtime Asphalt Cowboy
Texan's Avatar
Texan is on a distinguished road
Originally Posted by Papa John View Post
....Texan,
I'll do the reading. Btw: I was in Marine Boot Camp down in San Diego in 1972 with some of your brethren. They were always an interesting bunch. We (OU) play your boys (Texas) this weekend. Ought to be a great match up of programs. I see McCoy is much improved over last year and improving every week. He even has Bradford's efficiency rating beat. Have a good one and ride safe. Thanks for the tip.
John
Yeah, the ole Red River Shoot-out...ought to be a good game. Always is.
Good luck on your venture inside the motor. One thing to be real observant on is the timing marks on the cam and the oil pump. I've had my '96 Evo apart numerous times and it's really a no brainer. Make sure you've got the book handy.
o~\o
"was informed last night that I would be considered an "Asphalt Professional Bovine Relocation Specialist"
Texan is offline   Reply With Quote
Old 10-06-2008, 11:25 PM   #17 (permalink)
Papa John is on a distinguished road
Roadhog96,
Here is the ebay url... shows ten available.
http://cgi.ebay.com/ebaymotors/ws/eB...2BSI%26otn%3D4
Let me know if that does not get you there. John
Papa John is offline   Reply With Quote
Old 10-07-2008, 11:55 AM   #18 (permalink)
Lakerat is on a distinguished road
Buy two identical nose cone gaskets and use one of them for setting your end free play of the cam and use the fresh one for final assembly.
Check the breather gear for ANY imperfections around the outside diameter. If there are any grooves, they will work as carriers for trash that will eat up the case. Steel breather gears will not carry this trash. (Mine had a little extra whine after the steel gear)
Check the lifter blocks for any side wear around the lifter roller guide at the bottom of the slots.
Be sure when installing the needle bearing that it is behind the winged washer boss to allow oil flow.
Lakerat is offline   Reply With Quote
Old 10-07-2008, 12:08 PM   #19 (permalink)
Thanks for the input Lakerat..
Old 10-07-2008, 12:27 PM   #20 (permalink)
JohndeereB is on a distinguished road
What is the diminsion for the bearing depth? my puller has the shoulder .020
but I thought it is .005 to .010.
JohndeereB is offline   Reply With Quote
Old 10-07-2008, 05:16 PM   #21 (permalink)
Roadhog96 is on a distinguished road
Thanks Papa John - Im always on the quest for more knowledge - this forum, with all its qualified people who hang out here is better reading than most books. The link worked great.
Thanks Roadhog96
Roadhog96 is online now   Reply With Quote
Old 10-08-2008, 09:33 AM   #22 (permalink)
JohndeerB,
This is an excerpt from a RKJohn post last month:
"Tap new one in using cam to 005-010 below flush with case, or just a bit down. You will hear it bottom out but be carefull here. Go easy".
I didn't see a spec mentioned in my Service Manual so this is the only mention I've seen anywhere of how deep to set the bearing.
By the way, there were five pages of instructions at the following site: http://www.nightrider.com/biketech/hdcaminstall00.htm
Don't know why they broke it into five pages but its not too cumbersome to page through. They had some things I hadn't pulled out after watching the DVD and they removed more than I planned on removing for the job. I have been busy reading about the gears and push rods and what tools I was going to need and hadn't even looked at exhaust pipe clearance, etc.
Hope it is useful,
John
