SportbikeTrackGearCustom DynamicsProCharger.comDiamond Bar ChoppersBikeBandit Original Bike SpiritsFuel MotoLeslie Kay's
Old 07-04-2005, 04:22 PM   #1 (permalink)
jtee1340 is on a distinguished road
Clearance checks
I have a 1999 Fatboy that I am doing some engine mods to and would like some help from the collective here.
(New stuff)
SE heads
10.5 forged pistons .005'
SE11 cam
(Previous mods)
Have Dyna 2000 ignition
CV carb with Thunderslide kit
Adjustable pushrods
Thunderheader
Using James base gasket, SE headgaskets
My main question is with the cam lift pretty light-508 or so will I have clearance problems? Will this cam work for this setup? It was recomended to replace the SE4 I had been running for its longer duration.
I have been reading this forum for a little while and have gotten some good info here.
Thanks for any help
jtee1340 is offline   Reply With Quote
Old 07-04-2005, 08:07 PM   #2 (permalink)
99nighttrain is on a distinguished road
I've got a 1999 Night Train with the following:
stock heads
SE 11 cam
Mikuni HSR 42
SE single fire ignition
SE a/c
Sampson 2 1/4" Big Guns w/ThunderMonsters
With the SE 11 cam, you'll lose a little on the bottom end, but from 3 grand on, it will truly SCREAM.
I would bet with the compression bump and SE heads, you won't lose as much on the bottom as I did. Let me know how it turns out, the SE heads are next on my list.
99nighttrain is offline   Reply With Quote
Old 07-04-2005, 08:13 PM   #3 (permalink)
>>> The Curmudgeon <<<
barrybasinger
Originally Posted by jtee1340
I have a 1999 Fatboy ...
You should not have any clearance problems, as the TDC lift is very close. I'm assuming you have the SE pistons and you're installing the cam without advance or retard.
HD calls the 11 a "HP" cam, while the 4 is a "TQ" cam. If you like it after you get it together, good, but if you feel as if it's got a bit of a hole in the bottom end, you might try re-gearing it. A 29-tooth tranny pulley might do it. Or you could try a 30-tooth tranny pulley with a 70-tooth rear pulley. Either way, you might need a new belt, so include that in the budget just in case.
I also think this combination might be sensitive to exhaust, so drag pipes, big diameter pipes, or mufflers without baffles would probably not be the best choice. I'd probably try the stock pipes with Supertrapp slip-ons for the options they give you, but then I like that look. Many don't.
(Ooops. After I posted, I noticed you have the T-Header. These might cause a little bit of a hole in the bottom, but since you've got it, think about the gearing change I mentioned).
HD has published dyno charts for this combination in several of their catalogs in the past. I've been able to exceed their charts for similar combinations that I've built, so I don't think they're overly-optimistic generally. You should be able to get close.
BB
Five Simple Rules:
- Free Your Heart From Hatred
- Free your Mind From Worries
- Live Simply
- Give More
- Expect Less
...and "Refuse to justify your opinions, but always be prepared to discuss them"
barrybasinger is offline   Reply With Quote
