SportbikeTrackGearFuel MotoBikeBandit Diamond Bar ChoppersMotorcycle.comCycleGear.comPowerstar Sparkplugs
Old 05-08-2005, 02:06 PM   #1 (permalink)
98fxstc is on a distinguished road
EVO Derby Cover O-ring
OK whats the trick. I spent 40 minutes before I finally gave up.
I lubed my bike and was putting a new inspection cover gasket
as well as a new O-ring for the derby cover per the service manual.
The O-ring seems too big it absolutley will not stay in place. Is there
a trick to it? I finally just put the original O-ring back. Maybe I was given
the wrong one by the dealer? Is the EVO and Twin Cam different sizes???
98fxstc is offline   Reply With Quote
Old 05-08-2005, 03:17 PM   #2 (permalink)
95 FXST is on a distinguished road
Use alot of appoxy. Helps it stay in place and creates an additional seal.
95 FXST is offline   Reply With Quote
Old 05-08-2005, 04:24 PM   #3 (permalink)
PatriotARK
Those things are worse than tryin to stuff a wet noodle up a wildcat's ass.....I finally spent the bucks and got one of the new style. Worked like a charm! Fiber type gasket with molded in o ring. Try it and you'l love it!
PatriotARK is offline   Reply With Quote
Old 05-08-2005, 06:36 PM   #4 (permalink)
I would have tried a new gasket.. But the parts counter guy said that it isnt
for my 1998 EVO engine. Just twin-cams... So I am stuck with the wet noodles
Old 05-08-2005, 07:44 PM   #5 (permalink)
No they have the three hole and the five hole gaskets.....!
Old 05-08-2005, 07:56 PM   #6 (permalink)
hdmd88.. That figures.. He didnt seem to be the sharpest knife in the drawer... I even mentioned the gasket and he said it was 5 hole only.. I'm taking this O-ring back in the morning.....
Old 05-08-2005, 08:15 PM   #7 (permalink)
sailordb is on a distinguished road
I have stuffed the wet noddle up the wildcat's ass. I put chassis grease on the o-ring and stick it in the groove and put the cover on by holding the bottom in place and then flatting it out. I tried that gasket. Leaked like a shive.
sailordb is offline   Reply With Quote
Old 05-08-2005, 08:58 PM   #8 (permalink)
Phemus
steveusmc's Avatar
steveusmc is on a distinguished road
You can use petroleum jelly (vaseline) to hold the o'ring in place also. Should work for ya and won't hurt anything. When in doubt..grease it!!
Semper Fi,
Steve...Pensacola
steveusmc is offline   Reply With Quote
Old 05-08-2005, 09:55 PM   #9 (permalink)
Retired Navy - MCPO
Ed Y's Avatar
Put it in the freezer for 15-20 minutes. Be careful about putting grease or too much of anything on the O-ring to hold it in place. This is the major cause of causing the derby cover to warp as you're tightening it if you've got a lot on there.
The plain O-ring was used on Evo's. The newer style, more like a quad seal, with small nubs on it was made for both Evo's and TC's. The one for Evo's was marked with a white dot on it. One for TC's did NOT have a white dot on it.
Ed Y
2002 FLTRI
I yam what I yam.
Old 05-13-2005, 10:19 PM   #10 (permalink)
I got the updated gasket and installed it without a hitch. No fuss no muss...
Old 05-22-2005, 09:12 AM   #11 (permalink)
V Gray is on a distinguished road
I put the bike in the freezer.
V Gray is offline   Reply With Quote
Old 06-08-2005, 03:20 PM   #12 (permalink)
Robert Edwards is on a distinguished road
I used the new one with nubs on it and it leaked like a kitchen strainer. Went back to the old one on my 98 EVO and find that if I clean the area with rubbing alcohol and then use a lube that I got for my swimming pool O-rings to stop them from leaking, all is good. Magic Lube comes in a small tube and is a teflon based lubricant made by Aladdin. Waterproof,non-melting, chemical & heat resistant. Just sticky enough to get the thing to stay in the groove and it works great!! See your swimming pool supplier.
Robert Edwards is offline   Reply With Quote
