Starter not engaging : V-Twin Forum: Harley Davidson Forums
Old 12-01-2003, 09:45 AM   #1 (permalink)
Clint Ward wants to know Dino or Syn?
Question Starter not engaging
I have a question about troubleshooting my starting system. When I engage the starter it doesn't turn the motor over. You can hear the starter turn over and occasionally it will turn the motor over and I need to know how to determine if it is the clutch in the starter drive gear or the solenoid.
Clint Ward is offline   Reply With Quote Quick reply to this message
Old 12-02-2003, 12:32 PM   #2 (permalink)
SIDEKICK wants to know Dino or Syn?
could be the jackshaft not engaging gear on clutch hub. starter motor shouldn't run without first the solenoid pulling in the plunger that kicks out the jackshaft. pull clutch cover and see if you can see anything wrong while someone hits starter button.
SIDEKICK is offline   Reply With Quote Quick reply to this message
Old 12-28-2003, 12:19 AM   #3 (permalink)
mutantrc wants to know Dino or Syn?
Hey Clint,
If the starter motor makes a high pitched noise every time you hit the starter button and only occasionally actually turns the motor over, your problem is the starter jack shaft. The starter motor is getting the power from the battery and the motor is spinning, but the shaft that extends out from the starter and makes contact with the gear on your clutch is not engaging. There can be a couple causes for this, but I can't remember them all. Good news it will be a simple and inexpensive fix. A new starter jack shaft only runs about $130.00 I think. Check the large gear around the outside of your clutch assembly. If that gear is missing teeth that is the cause, I don't have any idea on a price for that. Hope that helps some.
mutantrc is offline   Reply With Quote Quick reply to this message
Old 12-29-2003, 08:29 PM   #4 (permalink)
K McGee wants to know Dino or Syn?
The clutch is worn and slipping. Replace it! The solenoid is ok, otherwise the starter motor wouldn't run. The jack shaft will not engage unless the clutch is good.
K McGee is offline   Reply With Quote Quick reply to this message
Old 12-29-2003, 08:37 PM   #5 (permalink)
Correction, the jack shaft will engage with the clutch ring gear, but will not turn the engine over if the overrunning clutch is slipping. I had the same problem, would work some times and not other times, made a whirrrrring noise!
Old 01-03-2004, 02:18 AM   #6 (permalink)
Jeff S. wants to know Dino or Syn?
I am going to assume your bike is about 87 or newer. What you are describing sound typically like a starter clutch problem, ie, you hit the button, you hear the starter motor going, but nothing happens. Occasionally the bike starts. When you hit the starter button, it sends 12 volts and about an amp or so to the 86 position on your starter relay. This with the help of the 85 ground pulls closed the connection to the 87 and 30 positions on the relay allowing from the iginition to flow to the 50 connector or your green wire on the starter soleniod, which basically closes your solenoid allowing the big amps to run straight from the battery to the starter motor. There is a little more to it than that but I am sure you get it. If it is the starter clutch you can check it many ways, one of the easiest to do a basic check is to put you hand on the primary and hit the starter button. You should feel an hear the jackshaft engaging, and hear the starter turning, but not the engine. You could also just pop the derby cover and look with a flashlight and have someone hit the stater button also. You will see it popping in and out. If it was the realay you would not hear anything or maybe a very slight click/tick. If its your solenoid it might click in and out, and or make a louder clicking sound. There are specific test as for coil hold/release , starter testing etc per the book, that with a few jumpers and some patience is really easy. But it sounds like a typical starter clutch. About 130 bucks, and remember, a big killer of starter clutches is low or bad batteries.
Nostalgia
If its too loud
Your too old
Jeff S. is offline   Reply With Quote Quick reply to this message
Old 01-05-2004, 05:56 AM   #7 (permalink)
Thanks All for your input, it was in fact the starter drive gear clutch. The easiest way I found to check it was to remove the primary cover, the spark plug wires just in case it did engage and hit the starter button. you can watch the gear engage so you can tell the solenoid is working and if you look close you can see the jack shaft turn. You can then take hold of the starter gear and if it is bad you will be able to turn it both ways instead of just one like it is intended.
In order to repair it I had to remove the starter and take out the jack shaft so the gear would clear the gear on the clutch basket. You can also remove clutch and basket instead of the starter whichever you prefer. I had just replaced the stater and when I did I adjusted the clutc and had it just like I like it, so didn't want to mess with it. I purchased the new gear at an after market store here in Tulsa called Jacks. It ran me $30 and took about 3 hours to change which means it ook about 2 weeks with it being Christmas and all.
again Thanks for all the input!!
By the way does anyone know how to get rid of the ****ing new guy sign under the names?
Old 01-06-2004, 12:49 AM   #8 (permalink)
You should enjoy the FNG sign under your name. I gives you a license to do just about anything you want and say, hey, I didn't know, I'm an FNG. I'll try to do better.....
Nostalgia
If its too loud
Your too old
Old 01-06-2004, 06:15 AM   #9 (permalink)
This is true, but I don't mind admitting I don't know. Anybody to scared to ask is to stupid to learn. As expensive as repairs are I can't afford not to ask and learn.
Old 04-29-2004, 05:20 PM   #10 (permalink)
Registered User
Dynatherapy wants to know Dino or Syn?
I have the same issue that just started today on mine.
2002 FXDX.
Starter spins like a mother^&*, engages occasionally but then disengages and spins like a drill.
If I tap tap tap the starter botton I could get it to engage afetr about 5 tries but it would release and not engage again.
Is the fix for this issue the same as described above???
Thanks in advance.
And Just to Clarify:
Hit starter and it spins:
Obtain view of jackshaft gear & See if Jackshaft engages clutch basket -->
---If YES starter clutch is shot.
Thanks in advance.
Dynatherapy is offline   Reply With Quote Quick reply to this message
