cam cover : V-Twin Forum: Harley Davidson Forums
Old 11-04-2012, 04:34 PM   #1 (permalink)
Smithster is on a distinguished road
cam cover
There is a bolt that is leaking. So I opened the cover and one of the bolt holes is split.
any none repairs
Smithster is offline   Reply With Quote
Old 11-05-2012, 07:19 AM   #2 (permalink)
grndpndr is on a distinguished road
Where and how thats cracked you might get someone to prep it with a die grinder and tig weld it right in the frame for you. If your gonna have a crack in the case any where all that one is most likey one of the most straight forward, least stressful fixes I would think...
Good luck with it.....
grndpndr is offline   Reply With Quote
Old 11-05-2012, 12:34 PM   #3 (permalink)
jammer45u's Avatar
jammer45u is on a distinguished road
That's what I was thinking. It looks like that could be welded and re-tapped in the frame. Make sure you seal the case cavity best you can and flush the fluid quickly after it's put back together.
I bought a used sporty once that had a similar issue. The previous owner used JB Weld or something similar to make his repair. It was still holding when I sold it but I would have felt a whole lot better about the whole deal if it had been welded. I told the buyer about it so he wouldn't get the same surprise I did.
jammer45u is offline   Reply With Quote
Old 11-20-2012, 09:37 AM   #4 (permalink)
Originally Posted by jammer45u View Post
and re-tapped
If they run a bolt into the hole and use it to help clamp the broke piece back in line with before welding there should be no need to re-tap it....hopefully
Old 11-21-2012, 05:12 AM   #5 (permalink)
tussuck's Avatar
tussuck is on a distinguished road
Agree....just get it TIG welded up. Or if your really really stuck then put a bolt in it and JB Weld it.
Note...I lost all three bottom bolts on my cover. The threads all stripped out over the years so I have run a timesert int met of them now.
I prefer my engine blown not stroked!
D.L.R.A #1174
tussuck is offline   Reply With Quote
