10-25-2012, 07:17 PM
s&s v111 evo or somthing like that
hallo all my left case on my 80" softail 99 is bad
oil seeping out on the rear mount at the engine mount bolt
primary side and it still take the primaryoil in
the engine starting to burning oil to there is not to much oil in the bag have my eye on that. the crank is not so fine either
im realy pissed off on this engine
i have fhigting whith it in five years.
so i thinking new engine s&s v111 big bad engine bore 4 1/8" and stroke
4 1/8" sounds good in my head
or a nice little 88" build whith new s&s cases s&s cranck
jugs heads pistons etc. im a fan of 4 1/4" stroke or less.
any suggestions comments thoghts inputs gents.
thanks in advance speed.
Reason: one reason or five anhoter
10-25-2012, 08:27 PM
Good friend swapped in the 111.
Loves it.
2008 Road Glide
Phoenix Customs Bagger Brace
Glide Pro
Clearview windshield
107
CP flat tops
R&R Stage 3 heads, .030 gasket, 82cc chambers
Trued, welded, and balanced crank by Hyperformance
TMan 590 cams
SE AC
HPI 54mm TB
Supermeg with open cap and 15 discs
TTS tune by BVBob
2003 Indian Scout Deluxe
Aspen White (got it for my wife)
S&S "SuperStock" 88"
12" apes
Scary fast!
10-25-2012, 08:34 PM
Loves it.
did you now the hp tq numbers on your friends rear weel?
exh system?
fitment in the frame is it a softail?
regards speed
10-25-2012, 11:08 PM
No, he has it in a '95 Road King.
I don't have any idea of the actual numbers it makes.
I will tell you that I BARELY outrun him with my 107 which is a fairly strong runner.
2008 Road Glide
Glide Pro
107
CP flat tops
TMan 590 cams
SE AC
HPI 54mm TB
TTS tune by BVBob
12" apes
Scary fast!
10-26-2012, 08:11 PM
thanks for the inputs guydock.
anybody here having a high mile s&s v111 motor in?.
speed.
Reason: reason
11-04-2012, 03:02 PM
I hope others have better luck with their 111 than I have had. I put mine in winter of 2010, I had trouble also with running rough at 1800 rpm like the other poster has. Mine was mostly getting the jetting right, it's still not perfect but better. Now for the big whammy! The crank pin is soft on these engines aparantly. Mine started making noise on my way back from vacation. It has 19,000 miles on it. Any way the heat treating doesn't go deep enough on the pin, I'm hoping they have solved the problem. My engine went in the shop Aug.13 and I got it back Nov.2. To say the least I'm not too happy with S&S for taking so long during riding season. They ended up putting in a new crank assembly, lifters, oil pump, rods, pistons and rings, and valve springs. My engine isn't alone with this problem, the shop where I took it says he has fixed 2 others that were out of warranty. I was lucky I still had 2 months warranty left. As far as fitment to the bike no problem on mine, I put mine in a bagger.
11-04-2012, 06:20 PM
len tanks for the warning input
i can bet i running into the same problems if i buy one of those 111 for my last bucks i own
never had any luck whith my engines
had a s&s v107 for about 6 years ago.
that suddenly sounded like a can of loose bolts
was not happy whith that motor or s&s
was not happy whith the dealer that sold it to me
he dident care of my problems but he has buying a new
bike to him self instead.
maybe another engine for me but i dont know
which one to choose?. wonder why some 111 dont runns well
in low rpms?.
any more comments thoghts suggesstions gents.
regards speed.
Reason: two reasons
11-05-2012, 03:28 AM
This is my second S&S engine, the other one wasn't very good either, circlip came loose on piston pins, both pistons, and scored the cylinders at 30,000 miles. Lifter came apart at 60,000 miles and ate the cam and oil pump. I'm hoping the have improved the heat treating by now on the pins. The 111 is basically the same engine as the 117 and 124 just different stroke and valve springs and I haven't heard of any of those being bad. Duno, I'm just a lucky one I guess!
11-05-2012, 06:26 PM
thats not sounds good in my ears at all
maybe i let a good wrench i know here assembly a little s&s 88"
for me instead of the s&s factory assembled 111".
thinking of send s&s a question abauot these problems
whith some of the 111" if the problem is gone now sombody who belives
i get an answer on that?.
happy for more suggestions ideas comments inputs gents.
regards speed.
Reason: reason that
11-07-2012, 01:17 PM
regards speed.
My first S&S engine was a 88 wasn't too happy with that one after the piston thing. just my luck. As far as getting S&S to admit they have a problem, good luck. They tried to tell me the rod race was bad in my 111, I asked if the rod race ruined the crank pin or vice versa. I got blown off with them saying they weren't sure. The shop I took it to had already diagnosed the crank pin
11-07-2012, 06:19 PM
len thats my opinion to
s&s tell me when i called them on the phone when i had
my 107 s&s engine stated above there is no way that motor is bad because
its has left our building.
by the way i heard the 111" shold have at least 2800rpms to runns good sounds odd because its have a very good bottom end on the dyno chart s&s have on the home page and other dyno charts i have seeing.
regards speed.
11-08-2012, 01:21 PM
regards speed.
When I put the engine I thought about changing the transmission sprocket to gear it higher but because i pull a trailer with it and they said not to, keep it between 2500 and 3500 rpm when loaded
11-18-2012, 02:46 PM
any owners of high mile s&s v111" engines.
hi all shold be happy for more thoghts inputs comments etc
from owners of high mile S&s v111 engines.
happy for more info from owners of lower mile engines aswell.
thanks speed.
01-30-2013, 06:41 PM
someone that have more comments on the 111"?
or the s&s 113" 96" s&s how is those engines?
regards speed.
Reason: for a few
| Sponsored Links |
