New build problems : V-Twin Forum: Harley Davidson Forums
Old 09-03-2012, 09:00 PM   #1 (permalink)
ChuckB is on a distinguished road
New build problems
As mentioned in an earlier post, I finished my '86 FLTC.. The rains quit and I finally got to take her for a ride. Within a short time, I could hear a tapping or clicking noise, and the engine was running rough.. kind of shaking.. I turned around and came home.. Pulled the plugs and the rear one looked nice and brown.. the front one was white ! Very lean.. When it was running, it wasn't really poping out of the carb although it did it a time or two.. I checked the compression.. 130 in the front and rear. Maybe a manifold leak?? Would this cause the engine to make the tapping noise?
ChuckB is offline   Reply With Quote
Old 09-04-2012, 09:02 AM   #2 (permalink)
Thermodyne's Avatar
Thermodyne is on a distinguished road
Lifter? Did you replace them? Use adjustable push rods?
"All mankind is divided into three classes: those that are immovable, those that are movable, and those that move."
Thermodyne is offline   Reply With Quote
Old 09-16-2012, 12:36 PM   #3 (permalink)
Sorry for the late reply. I fixed the manifold leak... long story why that happened to begin with. Newer lifters and properly adjusted push rods.. wet 4 turns down how I always did it. When I put the stabilizer under the tank it lined up perfect with no stress.. I just put rear swingarm rubber (taiwan). I got the tank off and am getting a lawnmower tank to run it and see if it is something to do with that. If I dont see anything unusal, I will remove the cam cover and check the run out on the gear shaft.. I did too many things on this bike at one time..
Old 10-28-2012, 12:12 PM   #4 (permalink)
ductglue is on a distinguished road
did you prime the lifters?
ductglue is offline   Reply With Quote
Old 11-05-2012, 04:59 PM   #5 (permalink)
HarleyReece's Avatar
HarleyReece is on a distinguished road
Check that the jam nuts didn't come loose on your push rods. Happened to me when I first up the EV27 in. One of my push rods shortened up.
Sent from my iPhone using Motorcycle.com Free App
HarleyReece is offline   Reply With Quote
